Subscribe
Frequent Contributor
Trouble with Powershell script to call HTTP POST
[ Edited ]
Hi,
I am using WFA REST APIs and one of the API there is to invoke a restore operation on WFA.
More details about the API can be found here: http://10.63.119.80/rest/docs/resource_BackupResource.html
I am not able to figure out a way to invoke an HTTP POST call by passing content of type multipart/form-data.
the type of file(backup file) i am trying to upload is gzip or zip file.
The script i am using is:
function invoke-rest {
    param([string]$uri, [string]$body )
    [System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$true}
          #$enc = [system.Text.Encoding]::UTF8
    $request = [System.Net.HttpWebRequest]::Create($uri)
    $request.Credentials = New-Object system.net.networkcredential("admin","admin")
    $request.CookieContainer = New-Object System.Net.CookieContainer
    $boundary = "--------------"+(get-date -format yyyymmddhhmmss).ToString()
          $request.ContentType = "application/octet-stream; charset=UTF-8;"
    $request.Method = "Put"
    $request.keepAlive = $true
    $requestStream = $request.GetRequestStream()
    $streamWriter = New-Object System.IO.StreamWriter($requestStream)
    $streamWriter.Write($body)
    $streamWriter.flush()
    $streamWriter.close()
    [net.httpWebResponse]$response = $request.GetResponse()
    $responseStream = $response.GetResponseStream()
    $stream = new-object System.IO.StreamReader $responseStream
    $xmlDump = $stream.ReadToEnd()
    $output = [xml]$xmlDump
    $response.close()
    return $output
$uri = "http://localhost/rest/backups"
$method = "POST"
$body = @{}
$body = @{"name"="backupFile"; "filename"=[IO.File]::ReadAllBytes("C:\Users\Administrator\Desktop\wfa_backup_AG-1_.sql.gz")}
invoke-rest $uri $body
The error i get is:
Exception calling "GetResponse" with "0" argument(s): "The remote server returned an error: (500) Internal Server Error
At C:\Users\Administrator\Desktop\restore.ps1:19 char:58
+     [net.httpWebResponse]$response = $request.GetResponse <<<< ()
    + CategoryInfo          : NotSpecified: (Smiley Happy [], MethodInvocationException
    + FullyQualifiedErrorId : DotNetMethodException
Any help is appreciated. You can also test a script here:
http://10.63.119.80/rest/backups
Thanks,
Anil
