Hello all, I am attempting to use the 5.1 NM SDK via Perl to automate some processes against a cluster mode 8.2 vServer. Based on the SDK documentation for the "NaServer::set_style" method my options for authentication against the filer are LOGIN, HOSTS, or CERTIFICATE. Since this is cluster mode and there is no longer a /etc/hosts.equiv file that means all I can use are LOGIN and CERTIFICATE. If I choose LOGIN I can access all of the functions of the API and everything works perfectly, however I don't really want to have to embed a username and password inside of a script.
I followed the article below to get CERTIFICATE authentication setup. I can tell that the CERTIFICATE authentication is working because I can use the API 'system-get-version' object to retrieve the version and other attributes from the vServer. However if I attempt to use any of the volume related APIs such as 'volume-get-iter' or 'volume-clone-get' I receive a failed results status from the NaServer::invoke_elem method with a reason of 'not authorized for that command'. It appears that there may only be a limited set of API functionality when using CERTIFICATE authentication over LOGIN.
Has anyone had success using CERTIFICATE authetication against an 8.2 cluster mode vServer? any insight would be appreciated! thanks!
https://communities.netapp.com/community/interfaces_and_tools/developer/blog/2013/07/30/using-sdk-with-certificate-based-authentication-cba
