Software Development Kit (SDK) and API Discussions
Using SDK with SSL certs authentication
vladimirzhigulin
Hi All,
I've been testing SDK for some time now, I'd like to use it for monitoring purposes. At this point I'd like to query my storage appliances without supplying my scripts user / password pair. Using SSL certificates is an obvious and supported approach I think.
Can you please provide me with a working example of connecting to a filer with SSL certs?
Thanks,
Vladimir
1 REPLY 1
BGESTWICKI
Hi vladimirzhigulin!  There is a pretty good little walkthrough for that process at https://communities.netapp.com/community/interfaces_and_tools/developer/blog/2013/07/30/using-sdk-with-certificate-based-authentication-cba, so hopefully that does the trick for you!
