Software Development Kit (SDK) and API Discussions
how to get performance data for physical storage controller (node) in c-mode
lb98
Is there a way to get the performance data for a specific physical storage controller in netapp c-mode?
I used API  PerfObjectGetInstance to pass in instance of a vserver to get performance data  for a vserver. But this api wont work for a specific physical storage controller.
What is the way to get the performance data for physical storage controller in c-mode?
Thanks!
2 REPLIES 2
AlexSun0302
Try the OnCommand Performance Manager or Havst
lb98
Thanks for the reply! I am trying to find out if there is a similar api like
PerfObjectGetInstances to get the performance data of storage controller (node) in cluster mode the same way as it is in 7 mode.
