Software Development Kit (SDK) and API Discussions
system-cli gives xml.parsers.expat.ExpatError: not well-formed error
ana_sgr_1985
Hi Everyone,
I am in peculiar situation where after migration of host from (change of IP), I want to flush the nblade access from the node/vserver for specific host and policy via automation:
I am trying to do that in using system-cli because there is no API available for this task ( in my knowledge, correct me if I am wrong here).
Here is my input NaElement:
<system-cli>
<priv>diagnostic</priv>
<args>
<arg>nblade</arg>
<arg>access-cache</arg>
<arg>flush</arg>
<arg>vserver</arg>
<arg>myVserver</arg>
<arg>node</arg>
<arg>myNode</arg>
<arg>address</arg>
<arg>myHostIPAddress</arg>
<arg>policy</arg>
<arg>myPolicy</arg>
</args>
</system-cli>
It errors out like this:
    p.Parse(xmlresponse, 1)
xml.parsers.expat.ExpatError: not well-formed (invalid token): line 5, column 0
It seems that line in xml input "<arg>access-cache</arg>" is not getting parsed. If I remove this line, API call goes through but obviously, I get command not found type output.
Is there a workaround for this?
Any and all suggestions are welcome.
Thanks
Anand
0 REPLIES 0
