Community
Daemon to check if SMO is running... if it's not, it will start SMO
Hi All,
This is neto from Brazil
How are you?
Captain Nascimento (https://twitter.com/@rodrigontap) and neto from Brazil (https://twitter.com/@netofrombrazil) have developed some sample scripts to demonstrate how to have a daemon script to check if SMO is running... If it is not running, it will start SMO.
#!/bin/bash
# smo-check --- Checking if SMO and SDU are running
# version 1.0
# by neto from Brazil   - @netofrombrazil
#    Rodrigo Nascimento - @rodrigontap
function startall() {
export count=`ps auxwww | grep "java -Xmx128m -XX:+HeapDumpOnOutOfMemoryError -enableassertions -cp /opt/NetApp/smo/webapp/WEB-INF/lib/smo/smo.jar com.netapp.dlm.ui.cli.SMOServerCLI start" | grep -v grep | wc -l`
if  [ "$count" == "0" ]; then
          smo_server start > /dev/null 2>&1
fi
terminatorFile="/home/oracle/.killchecksmo"
while true; do
          startall;
          if [ -f "$terminatorFile" ];
        then
            export state=`ps auxwww | grep $$ | grep -v grep | awk '{ print $8 }'`
          export pid=$$
            trap 'exit 0' TERM
            exec 3>&2
            exec 2> /dev/null
          kill $pid >/dev/null 2>&1
            sleep 1
            exec 2>&3
             exec 3>&-
          fi
sleep 1
done
To run:
nohup ./smo-check.sh &
if you want to stop the daemon, please do: touch /home/oracle/.killchecksmo
All the best
neto
NetApp - I love this company!
Comments
on ‎2014-08-01 03:42 AM
Hey great man, this is what I was searching for.
