Federated Backups in SnapCreator 4.0
Did you ever want to have a consistent backup of your Oracle or MySQL database that is running inside VM and also want to take a VMWARE snaspshot in the same workflow?
SnapCreator 4.0 provides you an option to achieve this.
If you have a setup where,
  VM1 -> Oracle
  VM2 -> MySQL
  VM3 -> Domino
You will be able to quiesce your applications now before taking your VM snapshots.
A new config parameter has been added called FEDERATED_APPLICATIONS.
You can provide list of configs that you want to backup before quiescing the VM itself.
This should be comma seperated list of profile@config
The existing default backup workflow has been updated to use this parameter, so before the main config is quiesced, all the configs present under FEDERATED_APPLICATIONS are quiesced in a parallel way and unquiescing is done in the reverse order.
Hypervisor + App Backup config is created as below.
If you choose Yes below, at the end of the creating Hypervisor config you will be thrown with a screen to create App Backup.
You may also click the Hypervisor+App backup to add your profile/config that you may already have.
