[Format_InvalidString] Error in SMSP 7.x
You may run into this error occasionally in SMSP 7.x (7.0, 7.1, 7.1.1) which is caused by a communication issue between the Control Service and the Control database. This causes Microsoft Silverlight to be unable to retrieve some resources (strings, icons, etc.) for the UI. In order to resolve this issue here are two things to try:
  1. Clear your Internet Explorer (browser) cache then re-open SnapManager for SharePoint Manager console, if this does not resolve your issue try #2.
  2. Restart the SMSP Control Service which will re-establish a connection with the Control database.
Error encountered in the SMSP Manager UI:
Error text:
Arguments:
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.20513.00&File=mscorlib.dll&Key=Format_InvalidString
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at AvePoint.Common.Module.JobMonitor.Behaviors.RibbonBehavior.AssociatedObject_ButtonClick(Object sender, AUIRibbonButtonClickEventArgs e)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at AvePoint.Common.AUI.AveRibbon.AUIRibbon.FireButtonClickEvent(RButton source)
at AvePoint.Common.AUI.AveRibbon.RButton.RButton_Click(Object sender, RoutedEventArgs e)
at AvePoint.Common.AUI.AveRibbon.RButtonBase.FireClickEvent()
at AvePoint.StorageOptimization.Gui.Xaml.GeneralSettings.BLOBProviderWizard.BLOBProviderWizardPage.FinishRunNowButton_ItemClick(Object sender, EventArgs e)
at AvePoint.Common.AUI.Controls.AUIButtonGroupItem.mButtonItem_Click(Object sender, RoutedEventArgs e)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
@NaSharePointGuy
