Community
Integrating Snap Creator into ASMLib (Clones)
Hi All,
This is neto from Brazil
How are you?
Here is a wonderful procedure created by the rock star Mike Doherty (NetApp) to integrate Snap Creator Framework into ASMLib (Clones) - Oracle environment.
We need to improve it a little bit (e.g. to handle multiple clones on the same host, error handling, etc) but this is a great start.
Check V2
#!/bin/ksh
# Created 9/17/13
# NetApp
# Authors:            Mike Doherty, Neto from Brazil, Greg Loughmiller
# Purpose:  Automate cloning with ASMLib, scan new luns, rename ASM Disks, rename DiskGroups
# - version 0.2
# Change Log:
# Created 9-17-2013
# Mod 9-18-2013
# replace string with dd -- much faster
# added better logic for disks, used config file instead of string/*
# added asmcmd mount of new DG clones
# NOTES:
# Best if run as ASM owner as asmcmd cmd is invoked to +ASM instance
# You can edit asmcmd and add sudo -E -u <owner> asmcmd mount <variable>
# This is if you add script in SC POST_CLONE_CREATE_CMD01= /script_name
# To automate process uncomment lines 66-68
# Variable Definitions
# p = current working directory
# b = original asm disk pulled from querydisk
# c = original DG pulled from device header
# Variables
p=`pwd`
sudo /usr/local/bin/ql-dynamic-tgt-lun-disc.sh -s -r << EOF
yes
EOF
# Remove exsisting files
rm renamedisks.sh
rm renamedg.sh
rm *.tmp
rm asm_*
sudo sanlun lun show -p |grep  -A 3 -i "cl_" |grep "DM-MP DevName:" |   awk '{print $3}' | while read i dummy
do
b=`sudo /etc/init.d/oracleasm querydisk /dev/mapper/$i | awk '{print $11}' | cut -d'"' -f2`
c=`sudo dd if=/dev/mapper/$i bs=1 skip=104 count=11`
echo "sudo /etc/init.d/oracleasm force-renamedisk /dev/mapper/$i CL$b" >> renamedisks.sh
echo "/dev/oracleasm/disks/CL$b $c CL_$c" >> asm_$c.conf
echo "renamedg phase=two dgname=$c newdgname=CL_$c config=asm_$c.conf" >> rndg.tmp
echo "asmcmd mount CL_$c" >> asm.tmp
done
sort rndg.tmp | uniq > renamedg.sh
sort asm.tmp | uniq > asm_mount.sh
sudo chmod 777 *
#$p/renamedisks.sh
#$p/renamedg.sh
#$p/asm_mount.sh
Some real data&colon;
[oracle@hps11][+ASM][~/ASM]$ ./new_mike.sh
Please make sure there is no active I/O before running this script
Do you want to continue: (yes/no)?
Scanning HOST: host0
Scanning HOST: host1
Found
0:0:0:4
0:0:0:5
0:0:0:6
0:0:1:4
0:0:1:5
0:0:1:6
1:0:0:4
1:0:0:5
1:0:0:6
1:0:1:4
1:0:1:5
1:0:1:6
11+0 records in
11+0 records out
11 bytes (11 B) copied, 0.000325 seconds, 33.8 kB/s
11+0 records in
11+0 records out
11 bytes (11 B) copied, 0.000323 seconds, 34.1 kB/s
11+0 records in
11+0 records out
11 bytes (11 B) copied, 0.000281 seconds, 39.1 kB/s
Renaming disk "/dev/mapper/360a98000486e2f4c533474674b62454[  OK  ]LARCH1":
Renaming disk "/dev/mapper/360a98000486e2f4c533474674b62424[  OK  ]LDATA1":
Renaming disk "/dev/mapper/360a98000486e2f4c533474674b62392[  OK  ]LCNTL1":
Parsing parameters..
renamedg operation: phase=two dgname=ARCH newdgname=CL_ARCH config=asm_ARCH.conf
Executing phase 2
Completed phase 2
renamedg operation: phase=two dgname=CNTL newdgname=CL_CNTL config=asm_CNTL.conf
Executing phase 2
Completed phase 2
renamedg operation: phase=two dgname=DATA newdgname=CL_DATA config=asm_DATA.conf
Executing phase 2
Completed phase 2
[oracle@hps11][+ASM][~/ASM]$ asmcmd ls
ARCH/
CL_ARCH/
CL_CNTL/
CL_DATA/
CNTL/
DATA/
REDO/
All the best
neto
NetApp - I love this company!
Comments
NetApp Employee on ‎2013-09-19 06:19 PM
If anyone has ideas to better this script please post.
Thanks,
Mike
