Community
Perfstat (password less) - Scripts
Hi All,
This is neto from Brazil
How are you?
When you are using perfstat even with --sshprivatekey-file it always ask to press Enter on the passphrase for SSH key.
How to fix it: (remember that you need to create perfstat user and public key on NetApp)
Linux and Mac
echo -ne '\n' | ./perfstat8 10.61.104.111 -t 6 --sshprivatekey-file=/Users/neto/.ssh/id_rsa --verbose --mode=cluster-mode --diag-passwd=cpoc1302
Nossa SenhoraSmiley Tongueerfstat neto$ echo -ne '\n' | ./perfstat8 1.1.1.1 -t 6 --sshprivatekey-file=/Users/neto/.ssh/id_rsa --verbose --mode=cluster-mode --diag-passwd=netapp
[09-04-2013 15:38:15]  INFO *------------- perfstat v8.1 (20130314_1964919) -------------*
[09-04-2013 15:38:15]  INFO Parsing CLI options.
[09-04-2013 15:38:15]  INFO Loading preset information from default preset
[09-04-2013 15:38:15]  INFO Total commands are : 526
[09-04-2013 15:38:15]  INFO Total PRESTATS commands are : 383
[09-04-2013 15:38:15]  INFO Total POSTSTATS commands are : 92
[09-04-2013 15:38:15]  INFO Total PARALLEL commands are : 51
[09-04-2013 15:38:15]  INFO Total PARALLEL_PRESTATS commands are : 0
[09-04-2013 15:38:15]  INFO Total PARALLEL_POSTSTATS commands are : 0
[09-04-2013 15:38:15]  INFO Requesting SSH passphrase from user.
[09-04-2013 15:38:15]  INPUT Enter passphrase for SSH key:
[09-04-2013 15:38:15]  INFO Please wait! trying to authenticate using SSH Key pairs.
Windows
Create a VBS file and add:
'VBScript Example
Dim oShell
Set oShell = WScript.CreateObject("WScript.Shell")
oShell.Run "c:\users\neto\desktop\perfstat\perfstat8 1.1.1.1 -t 6 --sshprivatekey-file=c:\users\neto\desktop\perfstat\id_rsa --verbose --mode=cluster-mode --diag-passwd=netapp"
oShell.AppActivate "C:\Users\neto\Desktop\perfstat\perfstat8.exe"
WScript.Sleep 300
oShell.SendKeys "{ENTER}"
Probably you will need to adjust your path on the windows script
All the best
neto
NetApp - I love this company!
