PowerShell Script Module to Get Lun Information for a Particular Pattern Search for LUN Name
Here's a custom PowerShell Script Module Using PS ToolKit to extract Lun Information for a Particular InitiatorGroup Name & Lunid.
function Get-NalUNMapping {
.DESCRIPTION
Gets Lun Information for a Particular Pattern Search for LUN Name
.EXAMPLE
Import-Module NaLUNbyMap
Get-NalunMapping
Get-NalunMapping | Export-Csv "FilerInfo.csv"
Get-NalunMapping -nlun "vol_DemoCCRN1"
Get-NalunMapping -nlun "vol_DemoCCRN1" | Export-Csv "FilerInfo.csv"
[CmdletBinding()]
param(
                    [Parameter(Mandatory=$false,ValueFromPipeline=$True,HelpMessage="Pattern Search for LUN Name")]
                    $nlun="/vol/"
$info1= Get-NaLun | Select @{Name="LUN";Expression={$_.path}},@{Name="Size";Expression={[math]::Round([decimal]$_.size/1gb,0)}},`
@{Name="OnlineStatus";Expression={$_.online}},`
@{Name="Group";Expression={([string]::Join(",",(Get-NaLun $_.path | get-nalunmap | select -ExpandProperty initiatorgroupname)))}},`
@{Name="LunID";Expression={Get-NaLun $_.path | get-nalunmap | select -ExpandProperty lunid}} | ? {$_.lun -match $nlun}
Return $info1
I can also pipe the output of this cmdlet to "Export-CSV" to extract the data in a csv format.
Comments
can we just get lun name instead of the entire path
could you please attach the module also or else pls refer the link to download
