The Need for Interface Speed - How Much is Enough?
Today there is support for 16GFC and 10GbE, and the next speed increases on the technology roadmap are 32GFC, and 40G Ethernet and FCoE.  The host and networks interfaces are always first to move to the higher speeds with storage systems transitioning last.  This chart summarizes a comparison between the speeds.
Speed
Clocking (Gbps)
Encoding (data/sent)
Data Rate (MBps)
8GFC
8.500
8b/10b
1600
10GFCoE
10.3125
64b/66b
2400
16GFC
14.025
64b/66b
3200
32GFC
28.050
64b/66b
6400
40GFCoE
41.225
64b/66b
9600
100GFCoE
103.125
64b/66b
24000
32GFC is expected to be available in 2014, and it’s expected that 40GFCoE and 100GFCoE which are based on 2010 standards will be used exclusively for Inter-Switch Link cores for the near future, thereby maintaining 10GFCoE as the predominant FCoE edge connection.
We all know that the volume and size of data is growing like crazy, but in many environments today’s current interface speeds are sufficient and not being fully utilized.  However, moving to a higher interface speed provides the following benefits:
  • Increased  throughput  (2-3x)
  • Reduced number of HBAs, NICs and switch ports required to achieve similar performance
  • Less cabling investment
  • Simplified manageability with reduced port counts
  • Less power consumption due to less HBAs, NICs and ports
What are your thoughts? Are current interface speeds sufficient or do we need 32GFC and 40GbE now?
Mike McNamara
Comments
Even for today's standards, we're slowly reaching a point where protocol speed increases will probably make more sense to be used as Targets than initiators. This is particularly true with the advent of Flash as an additional server side caching mechanism, where a significant amount of IO will not hit the wire.  Now the question is, whether storage arrays can sustain or even achieve, these levels of available throughput. An extremely difficult task for today's storage arrays.
Why not support FDR Infiniband?  It is available now.  I have never understood why Netapp has ignored FCoIB.
Lorie,  good question, but FDR Infiniband is not mainstream like FC and Ethernet and hard to justify.
