VMware Solutions Discussions
Issue with fresh install of VSC 5.0x6
joshlukens
I was trying to test VSC 5.0x6 and couldn't get the windows service to start after install.  After a few uninstalls/reinstalls and diving into the logs it appears the x6 installer doesn't create the SSL keystore so the following two files are missing:
C:\Program Files\NetApp\Virtual Storage Console\etc\keystore.properties
C:\Program Files\NetApp\Virtual Storage Console\etc\nvpf.keystore
The service fails to start when it can't find them.  The x1 beta creates them just fine.  Grabbing them from the x1 install, uninstalling, installing x6 and putting them in place works fine.  So looks to be just an issue with the installer on a fresh install.  This was all on 2008 R2 Std.
1 ACCEPTED SOLUTION
rubinsed1
Open an administrator command prompt.
Change directory to VSC\bin directory
Run vsc ssl setup
Enter a keystore password and press Enter.
Enter a key password and press Enter.
Problem should be fixed now.
4 REPLIES 4
rubinsed1
Run vsc ssl setup
markicardy
Re: Issue with fresh install of VSC 5.0x6
rubinsed1Level 3
Your response fixed the issue for me.  Thank you.
mszafran
I ran into a similar issue with the production version of VSC 5.0 on Windows 2012.
I needed to be administrator to run the manual commands.  I did an uninstall and ran the installer as administrator and things went straight through to the registration page.   It worked like a champ.
Sensus
This has happened to me on every single VSC 5 install I have encountered. It would be great if it installed properly the first time.
