VMware Solutions Discussions
Monitoring Tools for NetApp Filers
sanman2304
I know Operations Manager is the standard software package used to monitor the filers, but are there any other packages that can achieve the same results or better?
12 REPLIES 12
thomas_glodde
There is no other NetApp tool to monitor your filers besides operations manager.
There are other monitoring tools available tho like Microsoft System Center Operations Manager or the open-source solutions like nagios, cacti or opennms. They even have templates available for monitoring netapp systems.
prakash_aviva
Hi Sanman,
Pls check the following link:
http://www.manageengine.com/products/opstor/monitoring-netapp-fas.html
Though, i have not used this product, it looks good......
chris_algar
Can you tell me what you mena by monitoring? Is this capacity planning or health, or performance. There are a number of methods depending on what you are looking to do.
spence
If this is a Microsoft shop then consider using NetApp Appliance Watch module for MOM\SCOM as an alternative to Operations Manager, provided that monitoring is the only objective. If this is a Unix shop then consider configuring Syslog, but again only if monitoring is your objective. Operations Manager provides more than just monitoring.
steve_francis
For monitoring Netapps, I think LogicMonitor is better, in that it defaults to "monitor everything, all the time". i.e. point it at a NetApp, and all volumes are monitored for latency, usage, etc. All phsyical drives on all shelves are monitored for activity. All shelves are monitored.  Add a volume - it's monitored. You dont have to enable latency monitoring for a volume, so you dont get issues where a new volume was added, didn't have latency monitoring enabled in Ops Manager, so you don't know if the DB performance issue was due to volume performance or something else. LogicMonitor will notice a new volume was added, or PAM card installed, and start monitoring it. (And uses the API, so it can get things like per volume ops and  latency, fiber channel adapter utilization, etc, and other stuff not available via snmp)
It's also nice in that it can monitor everything else (windows, linux, databases, routers, etc).
Ops Manager is better as far as configuration and management of lots of NetApps, certainly, if you need to set up complex replications, etc.
russbbass
Has anyone had any experience with HP Storage Essentials?
https://h10078.www1.hp.com/cda/hpms/display/main/hpms_content.jsp?zn=bto&cp=1-11-271-273%5e43820_4000_100__
Russ Bass
Univita Health
4x3160
v7.3.2
b_ochisor
Hi Sanman,
I use home RRDs to monitor all our Filers : CPU usage, Net/iSCSI IOs, CIFS/NFS/FC ops, Disk Read ops / Write ops, disk usage, etc ... RRD is a very good OpenSource tool made for monitoring.
The only thing you have to worry about is getting the values of what you want to monitor; for that you can use SNMP or RSH. Everything else is taken care of by RRD : data storage, graphs, etc.
You can find a howto on building RRDs on my blog : http://bogdanochisor.blogspot.com/. For collecting data I use a Perl plugin from Nagios that has been adapted to read other OID entries. You can also modify the code to use "snmpget" or RSH commands (RSH is useful when values are not in the MIB, such as iSCSI Total Net IN or the number of packets per interface, etc).
Regards
sanman2304
Thank you for telling me about this.  I am not an opensource guy so I'm learning about this as I dive deeper into the NetApp\VMware world, which I must say am enjoying it quite a lot.
anthony01
Hey Sanman,
We started using a tool for our 3PAR arrays an we pointed it at our NetApp filers and it is working pretty good for us. The tool is called Arxview, www.arxscan.com they have trial version.
Hope this helps.
Ant
DBTUNA_JACKY
Check out http://www.dbtuna.com/netapp_monitor.php    DBTuna does, in fact, monitor NetApp at the controller level.
ORONA_MIKEL
pave
You can try free performance monitoring tool called STOR2RRD, opensource, supports NetApp FAS & E-series
Look at the demo site http://demo.stor2rrd.com
