Subscribe
NetApp-Content-Pack Installation for ONTAP 9
[ Edited ]
To install the content pack you have to forward the logs to VMware's Log Insight. The installation instructions for a cluster lists two commands that are both deprecated in version 9.
The event destination command is replaced by the event notification destination command, but the event route command doesn't seem to have a direct replacement.
What command do I use to add the destination to the route?
Thanks,
Gary
Re: NetApp-Content-Pack Installation for ONTAP 9
Hi,
Please refer http://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.dot-cm-cmpr-930%2Fevent__route__add-destinations.html
 event destination create command for information about creating destinations. To show all existing destinations and their attributes, use the event destination show command.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Hi,
any luck with this?
I'm interested if you can filter the logs properly within Log Insight and in your opinion if this is a good solution since the official content pack is not available anymore...
Thank you!
