VMware Solutions Discussions
Netapp VSC Restore virtual machine script
Alessio_LUX
Hello,
anybody knows where is possible to see the script about restoring virtual machine in VSC ?
i need to see the steps that the script follow when a restore virtual machine is requested by user .
Regards,
Alessio
3 REPLIES 3
YIshikawa
HI, Alessio!
You can restore VM by "smvi backup restore" command. Usage and example is detailed in guide as below.
I hope this helps.
https://library.netapp.com/ecmdocs/ECMP1392339/html/GUID-621C4F11-A03E-467A-8047-FFF801FB38E5.html
Alessio_LUX
Hello,
thanks for info but i'm looking for the exactly step that restore perform when you ask to restore a virtual machine.
When you perform a restore VM from a backup in VSC GUI you can see several task under "tasks Vmware".
Is it possible in your opinion to know which are the exactly step that a restore do ?
(clone datastore, mount, registered old vm, register new one,,,, etc etc etc )
regards,
Alessio
YIshikawa
Sorry, I misunderstood your first post. What you want to know is what VSC do inside when user initiate restore. Right?
At VM task level, you can check tasks in "Tasks & Events" tab for vCenter.
Or, you may get more detail from vpxd.log - but it is hard to read.
http://kb.vmware.com/kb/1021804
On VSC side, VSC operation is logged in C:\Program Files\NetApp\Virtual Storage Console\smvi\server\log\server.log
