Subscribe
Accepted Solution
Problems with VSC 6 with Data Ontap 8.1.4.P7
[ Edited ]
Our VMWare administrators are using the VSC plugin 6. About this plugin they also want to delete LUN's. By some LUN's they get the following error message:
faultCode : Server.Processing
faultString:'java.lang.RuntimeExeption : Current vCenter Server context is unknown'
faultDetail:'null'
In the log of the affected NetApp no error message is present. Does anyone have an idea why the error occur?
Re: Problems with VSC 6 with Data Ontap 8.1.4.P7
I'm seeing this on 8.1.4P8, as well.  Still looking...
I have a case opened at NetApp. Let's see what NetApp says.
Hi!,
Do you have any news? I'm having the same issue with VMWare 6 and DOT 8.1.4P8...
same probleme here, any news?
We have the issue in any interaction with VSC.
After a reboot of the vCenter Server (where the VSC was installed), we reconfigure storages in VSC and the problem was solved.
@Caludio: Thanks for your information. We will try it.
We are in contact with the NetApp Support. When we have a solution, we will announce it here.
Do you happen to have an update on this issue?
...any solution? We are still facing this issue Smiley Sad
Using the NetApp support we were able to solve the problem: VSC completely de-installed, deleted under Program Files, the corresponding folder manually and VSC reinstalled.
When upgrading from VSC 5 after 6 probably an error has occurred, therefore the complete installation.
