VMware Solutions Discussions
SMVI Backup to tape with Storage vMotion (svMotion) + using SMVI for single-file-restore from a tape-restored LUN
eranb
A prospect currently running on DMX raised a few question:
Scenario:
vSphere ESXi cluster
40TB of data (no DeDupe, obviously)
~50 LUNs, each ~1TB
Machines are migrated using vMotion and storage vMotion as needed
In the NetApp solution All LUNs are backed up to tape using NDMP
SMVI snaps will be saved online for 2 weeks
Questions:
1) when restoring a VM from tape (3 month old backup) - how can the backup operator know which LUN she should restore ? the VM might have been in any one of the LUNs at that time ?
     I was thinking that maybe there's a log inside SMVI that could show which VM was in each datastore at the time of the snapshot
2) If a LUN is restored from tape, and then mounted by the vSphere cluster, will SMVI be able to restore a single file from one of the VMs in this LUN ?
     I was thinking that there would be name conflicts and the LUN can't be mounted to the same cluster, but assuming we use another ESX server with a separate copy of SMVI installed maybe ... ???
Appreciate any inputs !!
Eran B
1 REPLY 1
radek_kubka
Hi Eran,
SMVI stores its own backup catalog (which is searchable) & even if you delete associated snapshot, the catalog entry stays in place. Of course if you actually  try to restore from a non existent snapshot, it will generate a nice error "could not find current snapshot"). But this way you will know in what datastore was the VM in question during backup.
I am not quite sure whether SMVI 2.0 Single File Restore will function in this circumstances, but you can always do that 'old school' way - restore snapshot, mount it to an ESX host (with option 'allow resignatures') and use a recovery VM to mount VMDK file in question & pull out a single file from it.
Regards,
Radek
