Subscribe
Re: SMVI FLOW-11019 Failure in VMgetVirtualMachineList
when i manually enter der VM name the SFR works.
All vm´s are registered in the datatsores.
Regards
Chris
That's good to know. IS there a distributed vSwitch in your environment?
Regards
Amrita
Hello Roland
Did you already get an answer from NetApp. I just tested it with VSC 2.1 and I'm still getting the error "FLOW-11019 Failure in VMgetVirtualMachineList: Did not find any VM". As soon as I move my VM to the root directory of my vCenter it works.
Cheers
Chris
Hi all,
this is now fixed in VSC2.1.2 according to NetApp. This was known as bug 437901. Release notes state this should be fixed. My customer is going to install this version soon. If i get feedback, I will post that here too.
