VMware Solutions Discussions
Trouble using HA Configuration Checker (ha-config-check.cgi) 2.0
MADISONDIOCESE
Hello,
I have a dual-controller FAS2040 and I'm trying to check my HA configuration. I'm having trouble using the HA Configuration Checker utility. I'm running through CLI on Windows. These are the commands I use to run the Configuration Checker:
C:\ha-config-check.exe -l <IPaddressFirstNode> <IPaddressSecondNode>
I have rsh enable on both controllers. And I get the following error when running the configuration checker:
'rsh' is not recognized as an internal or external command, operable program or batch file.
Cannot rsh into <IPaddressFristNode>
I've also tried with ssh but no luck either, I get the same error but with ssh instead of rsh.
Can you please help? Is there some configuration I'm missing?
Thanks!!
4 REPLIES 4
christin
Please send your feedback using the URL below:
http://support.netapp.com/NOW/download/tools/cf_config_check/
Regards,
Christine
martin_fisher
Hi - Just a quick thought, is the Windows Server a 2008 server? - if it is, make sure RSH has been installed, as it is not installed by default in 2008.
the HA ClusterConfig Checker.exe relies on this heavily.
Do you have DFM Operations Manager? - This has a Cluster Config Checker feature in later version.
Alternatively download and use plink.exe to create a batch file which should be able to invoke the .exe and run it against the NetApp filer.
Martin
MADISONDIOCESE
No, it's a Windows 7 Professional machine. I will check if I have RSH installed on my computer.
What is DFM Operations Manager?
martin_fisher
RSH.exe was removed as part of the standard install from Windows Vista and wasnt re-introduced in Windows 7 either. if its not installed, you will need to install the Windows7 package from MS for this utility.
http://www.microsoft.com/en-us/download/details.aspx?id=2391
DFM Operation Manager - (DFM - Data Fabric Manager). Its is a Web Based Console for managing NetApp Appliances, which ran from a Windows Server.
http://www.netapp.com/uk/products/management-software/operations-manager.html?euaccept=true.
It required a license, but allowed for multiple appliances to be managed by it, bit like VCenter for ESX.
It als had a ClusterConfig checking feature.
