VMware Solutions Discussions
Using e0M as Cluster Management Interface port ?
CLOCATEL75
Hi,
We are configuring a FAS6280 in cluster mode. When we created the cluster on first node, we choosed e0M as cluster management interface port. It works well. In case of HA failover, the cluster_mgmt is linked to a0a, a data ifgrp and not e0M on the second node. We can't do a migrate to node2/e0M. But it works with node2/a0a which is not connected to network admin switch...
stor-dc1-c105::*> network interface show -failover
         Logical         Home                  Failover        Failover
Vserver  Interface       Node:Port             Group Usage     Group
SVshared
         SVshared_lif1   stor-dc1-c105-01:a0a  system-defined
                             Failover Targets: stor-dc1-c105-01:a0a,
                                               stor-dc1-c105-01:e0M,
                                               stor-dc1-c105-01:e0c,
                                               stor-dc1-c105-01:e0f,
                                               stor-dc1-c105-01:e5a,
                                               stor-dc1-c105-01:e5b,
                                               stor-dc1-c105-01:e7a,
                                               stor-dc1-c105-01:e7b,
                                               stor-dc1-c105-02:a0a,
                                               stor-dc1-c105-02:e0c,
                                               stor-dc1-c105-02:e0e,
                                               stor-dc1-c105-02:e0f,
                                               stor-dc1-c105-02:e5a,
                                               stor-dc1-c105-02:e5b,
                                               stor-dc1-c105-02:e7a,
                                               stor-dc1-c105-02:e7b
stor-dc1-c105
         cluster_mgmt    stor-dc1-c105-01:e0M  enabled         clusterwide
                             Failover Targets: stor-dc1-c105-01:e0M,
stor-dc1-c105-01
         clus1           stor-dc1-c105-01:e0d  system-defined
         mgmt1           stor-dc1-c105-01:e0M  disabled
stor-dc1-c105-02
         clus1           stor-dc1-c105-02:e0d  system-defined
         mgmt1           stor-dc1-c105-02:e0M  disabled
                             Failover Targets: stor-dc1-c105-02:e0M
the command to migrate the port to node2/e0M fails :
stor-dc1-c105::*> network interface migrate -vserver stor-dc1-c105 -lif cluster_mgmt -source-node stor-dc1-c105-01 -dest-node stor-dc1-c105-02 -dest-port e0M
Error: command failed: Failed to migrate interface stor-dc1-c105;cluster_mgmt.
       migrate: invalid port.
                      Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
SVshared
            SVshared_lif1
                         up/up    10.1.4.61/22       stor-dc1-c105-02
        a0a     false
stor-dc1-c105
            cluster_mgmt up/up    10.1.0.70/22       stor-dc1-c105-01
        e0M     true
stor-dc1-c105-01
            clus1        up/up    192.168.192.101/24 stor-dc1-c105-01
        e0d     true
            mgmt1        up/up    10.1.0.68/22       stor-dc1-c105-01
        e0M     true
stor-dc1-c105-02
            clus1        up/up    192.168.192.102/24 stor-dc1-c105-02
        e0d     true
            mgmt1        up/up    10.1.0.69/22       stor-dc1-c105-02
        e0M     true
We find that e0M on node1 has data role whereas node2 has node-mgmt role
stor-dc1-c105::*> network port show
                                      Auto-Negot  Duplex     Speed (Mbps)
Node   Port   Role         Link   MTU Admin/Oper  Admin/Oper Admin/Oper
stor-dc1-c105-01
       a0a    data         up    1500  true/-     auto/full   auto/1000
       e0M    data         up    1500  true/true  full/full   auto/100
       e0a    data         up    1500  true/true  full/full   auto/1000
       e0b    data         up    1500  true/true  full/full   auto/1000
       e0c    data         down  1500  true/true  full/half   auto/10
       e0d    cluster      up    9000  true/true  full/full   auto/10000
       e0e    cluster      down  9000  true/true  full/full   auto/10000
       e0f    data         down  1500  true/true  full/half   auto/10
       e5a    data         down  1500  true/true  full/half   auto/10
       e5b    data         down  1500  true/true  full/half   auto/10
       e7a    data         down  1500  true/true  full/half   auto/10
       e7b    data         down  1500  true/true  full/half   auto/10
stor-dc1-c105-02
       e0M    node-mgmt    up    1500  true/true  full/full   auto/100
       e0e    data         up    1500  true/true  full/full   auto/10000
Is there a solution ? Does someone else use e0M as cluster management interface port ?
10 REPLIES 10
