VMware Solutions Discussions
VC 6.0 u3c and VSC 6.2.1 not work
sorawu
 When I upgrade VC 6.0 u3c and VSC 6.2.1,i can't finish "create rapid clones"
1 ACCEPTED SOLUTION
sugandhanarang
Hi Sorawu,
This issue was also reported with VC version 6.5U1, which is fixed in VSC release 6.2.1P1D5.
So, you can upgrade the VSC version to 6.2.1P1D5 as a fix for this issue with VC 6.0U3.
Link to download VSC : https://mysupport.netapp.com/NOW/download/software/vsc_win/6.2.1P1D5/
Thanks!
Sugandha
2 REPLIES 2
sugandhanarang
Hi Sorawu,
Thanks!
Sugandha
sorawu
@sugandhanarang wrote:
Hi Sorawu,
Thanks!
Sugandha
Hi sugandha
thx,this question has been solved
