Subscribe
VSC 2.1 can't add a controller, other problems
I upgraded to 2.1 from 2.01P1 to fix an issue with updating credentials when filer password changes were made.
I installed 2.1 and was able to add the controllers in Monitoring and Host Configuration section.
I was able to add one of the Storage Controllers in Provisioning and Cloning. Whe I attempt to add the second it fails with an unrepsonsive script message.
When I try to choose resources for the controller that was added An Error box pops up: "Unable to build the aggr, volume or interface lists"
I'm seeing this in the wrapper.log file:
INFO   | jvm 1    | 2011/06/06 09:58:31 | 2011-06-06 09:58:31,242 [1308435551@qtp-508277609-8] DEBUG com.netapp.kamino.server.ServerServiceImpl - Exit getFilers.
INFO   | jvm 1    | 2011/06/06 09:58:31 | [ERROR] Exception while dispatching incoming RPC call
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,697 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - Enter refreshFilerUsables.
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,697 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - Enter getFilers.
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,697 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - Enter loadFilers.
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,698 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - WARNING: loadFilers ignoring FileNotFoundException
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,698 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - Exit loadFilers.
INFO   | jvm 1    | 2011/06/06 10:03:28 | 2011-06-06 10:03:28,698 [879164629@qtp-508277609-2] DEBUG com.netapp.kamino.server.ServerServiceImpl - Exit getFilers.
INFO   | jvm 1    | 2011/06/06 10:03:28 | [ERROR] Exception while dispatching incoming RPC call
Have you looked at the kamino.log file?  Anything useful in there?
The output in the kamino.log file looks about the same:
2011-06-06 09:46:44,550 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Enter getFilers.
2011-06-06 09:46:44,551 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Enter loadFilers.
2011-06-06 09:46:44,551 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - WARNING: loadFilers ignoring FileNotFoundException
2011-06-06 09:46:44,552 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Exit loadFilers.
2011-06-06 09:46:44,552 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Exit getFilers.
2011-06-06 09:46:44,552 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - The datastore is not on netapp storage
2011-06-06 09:46:44,552 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Exit getDatastoreDedupeInfo.
2011-06-06 09:58:26,172 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter refreshFilerUsables.
2011-06-06 09:58:26,173 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter getFilers.
2011-06-06 09:58:26,173 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter loadFilers.
2011-06-06 09:58:26,176 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - WARNING: loadFilers ignoring FileNotFoundException
2011-06-06 09:58:26,176 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Exit loadFilers.
2011-06-06 09:58:26,176 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Exit getFilers.
2011-06-06 09:58:31,241 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Enter refreshFilerUsables.
2011-06-06 09:58:31,241 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Enter getFilers.
2011-06-06 09:58:31,241 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Enter loadFilers.
2011-06-06 09:58:31,242 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - WARNING: loadFilers ignoring FileNotFoundException
2011-06-06 09:58:31,242 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Exit loadFilers.
2011-06-06 09:58:31,242 (1308435551@qtp-508277609-8) DEBUG [ServerServiceImpl] - Exit getFilers.
2011-06-06 10:03:28,697 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter refreshFilerUsables.
2011-06-06 10:03:28,697 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter getFilers.
2011-06-06 10:03:28,697 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Enter loadFilers.
2011-06-06 10:03:28,698 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - WARNING: loadFilers ignoring FileNotFoundException
2011-06-06 10:03:28,698 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Exit loadFilers.
2011-06-06 10:03:28,698 (879164629@qtp-508277609-2) DEBUG [ServerServiceImpl] - Exit getFilers.
I'd suggest you open a support case with NGS.
I updated Java on the machine I was doing the configuration. After that I was able to add the controllers and now everything appears to work.
Re: VSC 2.1 can't add a controller, other problems
