Subscribe
VSC 4.0 / Vsphere5 / Fas2240 / DataOntap 8.1.1 / NFS - controllers not discovered
Hi ,
I've got a fas2240 / 8.1.1 to add to an existing infrastructure (Vsphere5 / VSC4.0 ) as NFS Datastores.
In VSC, when I had the controllers , they appear a few seconds as unknown and then disappear ...
Any hint ?
TIA , Reg/
Re: VSC 4.0 / Vsphere5 / Fas2240 / DataOntap 8.1.1 / NFS - controllers not discovered
Looks like opening a case with NetApp support will be your best shot. ( You need all the logs to troubleshoot this kind of a error).
1 think to make sure is that there is no license mismatch b/w the 2 controllers of the HA pair. ( I remember this was an old trick for a similar kind of problem).
Do you have any storage added to the the ESX cluster yet? Try adding a volume to the 2240 using the VSC and see if they appear....
7-mode I assume...
did you check whether they are configured correctly ( initators / tragets )
Hi ,
We had several operations to do on the server and ...
After applying SP1 for Windows2008R2 , everything is OK ....
Thanks to All
Regis/
