Subscribe
VSC 4.0 issue
Hi community
I am facing a problem after setting the new plugin VSC 4.0
My configuration
3 ESXi 5.0
1 FAS2040 HA running OnTap 8.1
4 datastores /luns using iscsi
I was able to add and see my controller without any problem
but I'm getting "No controllers found please add using monitoring and host configuration capability" in the Provisioning and Cloning tab
But I did it , and i can see my volume etc.....
also the backup tab didn't show me any entities
I've read carefully release note and documentation, but no idea
httpd.admin.enable is on
Your help will be appreciate
Best regards
Isa
Re: VSC 4.0 issue
Does anyone use this new version VSC4.0
and can use the Provisioning and Cloning tab
I did other test , but still not working
VSC is installed on Windows 2008R2 server which is also the vCenter
Re: VSC 4.0 issue
Hi have exactly same issue
BR Andy
Re: VSC 4.0 issue
Hi RICCO4400
i have found a Problem. We had installed Ontap 8.1 and the Multistore license was installed but not enabled. After enable this license everything ist running fine.
BR Andy
Re: VSC 4.0 issue
We have same problem. Any suggestions?
Re: VSC 4.0 issue
flexclone licensed on the controllers?
as for backup & recovery tab, it needs its own credentials/controller adding
Re: VSC 4.0 issue
Hi Aleksey
please check the camino log in the VSC. If you find any entrys with licensed features who are not enabled, then the Script will be aborted. Enable all licensed features on Filer will solve the problem. You may have to restart the Framework. I had last week this issue with FCP on a filer. It was licensed but not enabled.
Re: VSC 4.0 issue
Hello,
I want to confirm this solution (enabling licensed features) worked for me - thanks for sharing.
Harry
Re: VSC 4.0 issue
please look at
https://kb.netapp.com/support/index?page=content&id=2017115&cat=VIRTUAL_STORAGE_CONSOLE_VMWARE_4.1&actp=LIST
try
connet ssh or console FAS2040
options
licensed_feature.fcp.enable on
licensed_feature.iscsi.enable on
and reboot VcenterServer & VSC(if others machine runnning)
