VMware Solutions Discussions
VSC Automation
mbeattie
Hi All,
VSC can be automated using PowerShell to invoke API SOAP requests via web services.
I'm currently writting a function library for VSC4.X to replicate the functionality the previously existed with the Kamino PowerShell Module for VSC2.X.
See example code below, hope this helps to accelerate your development!
'Script Name : vsc.ps1
'Author      : Matthew Beattie
'Email       : mbeattie@netapp.com
'Created     : 04/08/13
'Description : Example of VSC automation using web services API.
'Functions Section
Function Connect-VSC{
   .SYNOPSIS
   Connect-VSC Connects to the NetApp (VSC) Virtual Storage Console using web services
   .DESCRIPTION
   Connects to the Virtual Storage Console and returns a connection.
   .PARAMETER
   IPAddress accepts a string containing the VSC IPAddress
   .PARAMETER
   PortNumber Accepts an Integer containing the Port Number the VSC is listening on.
   .EXAMPLE
   Connect-VSC -IPAddress 192.168.0.100 -PortNumber 8143 -Credentials $credentials
   .NOTES
   The Function returns a connection object to the VSC using the Web Services API.
   Param(
      [Parameter(Position=0,
         Mandatory=$True,
         ValueFromPipeLine=$True,
         ValueFromPipeLineByPropertyName=$True)]
      [String]$IPAddress,
      [Parameter(Position=1,
         Mandatory=$True,
      [Int]$PortNumber,
      [Parameter(Position=2,
         Mandatory=$True,
      [System.Management.Automation.PSCredential]$Credentials
   $connection = ""
   #'Bypass SSL certificate confirmation
   [System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$True}
   #'Get the web service proxy object of the SOAP API for the VSC
   [String]$uri = "https://$ipAddress`:$portNumber/kamino/public/api?wsdl"
   Try{
      [System.Web.Services.Protocols.SoapHttpClientProtocol]$connection = `
      New-WebServiceProxy -uri $uri -Credential $credentials -ErrorAction Stop
   }Catch{
      Write-Host ("Error """ + $Error[0] + """ Connecting to ""$uri""")
      Break;
   Return $connection;
}#End Function
Function Get-VSCvCenterVersion{
   .SYNOPSIS
   Get-VCenterVersion enumerates the Virtual Center Version
   Param(
         Mandatory=$True,
      $Connection,
         Mandatory=$True,
      [String]$IPAddress,
         Mandatory=$True,
   #'Enumerate the username and password from the credential object.
   [String]$vcVersion = ""
   [String]$domain    = $credentials.GetNetworkCredential().domain
   [String]$user      = $credentials.GetNetworkCredential().username
   [String]$password  = $credentials.GetNetworkCredential().password
   [String]$username  = "$domain\$user"
   #'Get the object of the namespace
   $namespace = $connection.GetType().Namespace
   #'Create a request  spec from the NameSpace
   $requestSpecType = ($namespace + '.requestSpec')
   $requestSpec     = New-Object ($requestSpecType)
   #'Set the properties of the RequestSpec object.
   $requestSpec.serviceUrl = "https://" + $ipAddress + "/sdk"
   $requestSpec.vcUser     = $username
   $requestSpec.vcPassword = $password
   $vcVersion              = $connection.getVCenterVersion($requestSpec)
   Return $vcVersion;
}#End Function
Function Get-VSCManagedObjectRef{
   .SYNOPSIS
   Param(
         Mandatory=$True,
      [System.Web.Services.Protocols.SoapHttpClientProtocol]$Connection,
         Mandatory=$True,
      [String]$IPAddress,
         Mandatory=$True,
      [String]$Name,
      [Parameter(Position=3,
         Mandatory=$True,
      [String]$Type,
      [Parameter(Position=4,
         Mandatory=$True,
   [String]$moref     = ""
   #'Create a namespace object from the connection object
   [System.Object]$namespace = $connection.GetType().Namespace
   #'Create a requestspec Object from the NameSpace object
   [System.Object]$requestSpecType = ($namespace + '.requestSpec')
   [System.Object]$requestSpec     = New-Object ($requestSpecType)
   #'Enumerate the Managed Object Reference based on the object type.
   Switch($Type){
   Switch($Type){
      "ClusterComputeResource"{
         [String]$moref = $connection.getMoref($Name, "ClusterComputeResource", $requestSpec)
      "Datacenter"{
         [String]$moref = $connection.getMoref($Name, "Datacenter", $requestSpec)
      "Datastore"{
         [String]$moref = $connection.getMoref($Name, "Datastore", $requestSpec)
      "Folder"{
         [String]$moref = $connection.getMoref($Name, "Folder", $requestSpec)
      "HostSystem"{
         [String]$moref = $connection.getMoref($Name, "HostSystem", $requestSpec)
      "ResourcePool"{
         [String]$moref = $connection.getMoref($Name, "ResourcePool", $requestSpec)
      "VirtualMachine"{
         [String]$moref = $connection.getMoref($Name, "VirtualMachine", $requestSpec)
   Return $moref;
}#End Function
#'Initialization Section
[String]$scriptPath     = Split-Path($MyInvocation.MyCommand.Path)
[String]$scriptSpec     = $MyInvocation.MyCommand.Definition
[String]$scriptBaseName = (Get-Item $scriptSpec).BaseName
[String]$ipAddress      = "192.168.100.19"
[Int]$portNumber        = 8143
[String]$datacenter     = "Testlab"
[String]$datastore      = "Datastore1"
[String]$username       = "testlab\administrator"
$password               = Read-Host "Please enter the password for user ""$userName""" -AsSecureString
$credentials            = New-Object System.Management.Automation.PSCredential -ArgumentList $userName, $password
#'Connect to the VSC using the web service API.
Try{
   $connection = Connect-VSC -IPAddress $ipAddress -PortNumber $portNumber -Credentials $credentials -ErrorAction Stop
   Write-Host "Connected to VSC on IPAddress ""$ipAddress"" on Port ""$portNumber"""
}Catch{
   Write-Host "Failed connecting to ""$ipAddress"" on PortNumber ""$portNumber"""
   Break;
#'Enumerate the Virtual Center Version.
Try{
   $vcVersion = Get-VSCvCenterVersion -Connection $connection -IPAddress $ipAddress -Credentials $credentials -ErrorAction Stop
   Write-Host "Enumerated Virtual Center Version as ""$vcVersion"""
}Catch{
   Write-Host "Failed Enumerating Virtual Center Version"
   Break;
#'Enumerate the Managed Object Reference for the DataCenter object.
Try{
   [String]$dataCenterMoref = Get-VSCManagedObjectRef -Connection $connection -IPAddress $ipAddress -Name $datacenter -Type "Datacenter" -Credentials $credentials -ErrorAction Stop
   Write-Host "Enumerated Managed Object Reference for ""$datacenter"" as ""$dataCenterMoref"""
}Catch{
   Write-Host "Failed Enumerating Managed Object Reference for ""$datacenter"""
   Break;
Try{
   [String]$dataStoreMoref = Get-VSCManagedObjectRef -Connection $connection -IPAddress $ipAddress -Name $datastore -Type "Datastore" -Credentials $credentials
   Write-Host "Enumerated Managed Object Reference for ""$datastore"" as ""$dataStoreMoref"""
}Catch{
   Write-Host "Failed Enumerating Managed Object Reference for ""$datastore"""
   Break;
Example output:
Connected to VSC on IPAddress "192.168.100.19" on Port "8143"
Enumerated Virtual Center Version as "5.1.0"
Enumerated Managed Object Reference for "Testlab" as "Datacenter:datacenter-2"
Enumerated Managed Object Reference for "Datastore1" as "Datastore:datastore-16"
Watch this space, i'll be adding to the library of functions. Hope this helps
Cheers Matt
Here is another example of how to invoke methods using the web services API. The following example will resize an NFS datastore
Example output:
Connected to VSC "testvc01" on Port "8143"
Enumerated Managed Object Reference for "datastore1" as "Datastore:datastore-16"
Resizing datastore "Datastore1" to "200GB"
Initiated Resize for datastore "Datastore1". VCenter TaskID "Task:task-262"
   .SYNOPSIS
   .DESCRIPTION
   .PARAMETER
   VSCHostName accepts a string containing the NetBIOS Hostname of the VSC server.
   .PARAMETER
   .EXAMPLE
   Connect-VSC -VSCHostName TESTVC01 -PortNumber 8143 -Credentials $credentials
   .NOTES
   Param(
         Mandatory=$True,
      [String]$VSCHostName,
         Mandatory=$True,
      [Int]$PortNumber,
         Mandatory=$True,
   $connection = ""
   [String]$uri = "https://$vscIpAddress`:$portNumber/kamino/public/api?wsdl"
   Try{
   }Catch{
      Break;
   Return $connection;
}#End Function
   .SYNOPSIS
   Param(
         Mandatory=$True,
         Mandatory=$True,
         Mandatory=$True,
      [String]$Name,
         Mandatory=$True,
      [String]$Type,
         Mandatory=$True,
   [String]$moref     = ""
   $requestSpec.serviceUrl = "https://" + $vscHostName + "/sdk"
   Switch($Type){
   Switch($Type){
      "Datacenter"{
      "Datastore"{
      "Folder"{
      "HostSystem"{
      "ResourcePool"{
      "VirtualMachine"{
   Return $moref;
}#End Function
Function Update-VSCDataStoreSize{
   .SYNOPSIS
   Resize-VSCDataStore resizes a datastore
   Param(
         Mandatory=$True,
         Mandatory=$True,
      [String]$ControllerHostName,
         Mandatory=$True,
         Mandatory=$False,
      [String]$VFilerHostName,
         Mandatory=$True,
      [String]$Protocol,
      [Parameter(Position=5,
         Mandatory=$True,
      [Bool]$ThinProvision,
         Mandatory=$True,
      [String]$DataStoreName,
      [Parameter(Position=6,
         Mandatory=$True,
      [String]$DataCenterName,
      [Parameter(Position=7,
         Mandatory=$True,
      [Int]$dataStoreSizeGB,
      [Parameter(Position=8,
         Mandatory=$True,
      [System.Management.Automation.PSCredential]$ControllerCredentials,
      [Parameter(Position=9,
         Mandatory=$True,
      [System.Management.Automation.PSCredential]$VSCCredentials
   [String]$domain    = $ControllerCredentials.GetNetworkCredential().domain
   [String]$user      = $ControllerCredentials.GetNetworkCredential().username
   [String]$password  = $ControllerCredentials.GetNetworkCredential().password
   #'Set the username for the domain or local user.
   If($domain -ne ""){
   }Else{
      [String]$username = $user.Split("\")[0]
   #'Create a controllerSpec Object from the NameSpace object and set properties.
   [System.Object]$controllerType           = ($namespace + '.controllerspec')
   [System.Object]$controllerSpec           = New-Object ($controllerType)
   [System.Object]$controllerSpec.username  = $username
   [System.Object]$controllerSpec.password  = $password
   [System.Object]$controllerSpec.ipAddress = $ControllerHostName
   [System.Object]$controllerSpec.ssl       = $True
   #[System.Object]$controllerSpec.port     = 443
   #'Set the vFiler context if the parameter was parsed to the function
   If($VFilerIPAddress -ne $Null){
      [System.Object]$controllerSpec.passthroughContext = $VFilerHostName
   $controllerSpec
   [String]$domain    = $vscCredentials.GetNetworkCredential().domain
   [String]$user      = $vscCredentials.GetNetworkCredential().username
   [String]$password  = $vscCredentials.GetNetworkCredential().password
   #'Enumerate the Managed Object Reference for the Datastore object.
   Try{
      [String]$objectType     = "Datastore"
      [String]$dataStoreMoref = Get-VSCManagedObjectRef -Connection   $connection     `
                                                        -VSCHostName  $vscHostName    `
                                                        -Name         $dataStore      `
                                                        -Type         $objectType     `
                                                        -Credentials  $vscCredentials `
                                                        -ErrorAction  Stop
   }Catch{
      Break;
   Try{
      [String]$objectType      = "Datacenter"
      [String]$dataCenterMoref = Get-VSCManagedObjectRef -Connection   $connection     `
                                                         -Name         $dataCenter     `
                                                         -Type         $objectType     `
                                                         -ErrorAction  Stop
      Write-Host "Enumerated Managed Object Reference for ""$dataCenter"" as ""$dataCenterMoref"""
   }Catch{
      Write-Host "Failed Enumerating Managed Object Reference for ""$dataCenter"""
      Break;
   #'Create a dataStoreSpec Object from the NameSpace object and set properties.
   [System.Object]$dataStoreType                   = ($namespace + '.datastorespec')
   [System.Object]$dataStoreSpec                   = New-Object ($dataStoreType)
   [System.Object]$dataStoreSpec.controller        = $controllerSpec
   [System.Object]$dataStoreSpec.thinProvision     = $thinProvision
   [System.Object]$dataStoreSpec.Protocol          = $protocol.ToUpper();
   [System.Object]$dataStoreSpec.protocolSpecified = $True
   [System.Object]$dataStoreSpec.numDatastores     = 1
   [System.Object]$dataStoreSpec.sizeInMB          = ($dataStoreSizeGB * 1024)
   [System.Object]$dataStoreSpec.sizeInMBSpecified = $True
   [System.Object]$dataStoreSpec.datastoreNames    = $dataStoreName
   [System.Object]$dataStoreSpec.mor               = $dataStoreMoref
   [System.Object]$dataStoreSpec.targetMor         = $dataCenterMoref
   [System.Object]$dataStoreSpec.wrapperVol        = $True
   #'Invoke the ResizeDataStore Method.
   [String]$taskID = ""
   Trap [System.Management.Automation.MethodInvocationException]{
      Write-Host ("Error " + $_ + " Resizing datastore ""$dataStoreName""") Stop
   Write-Host "Resizing datastore ""$dataStoreName"" to ""$dataStoreSizeGB`GB"""
   [String]$task   = $connection.ResizeDatastore($dataStoreSpec, $requestSpec)
   [String]$taskID = $task.SubString($task.LastIndexOf(" ") + 1)
   Return $taskID;
}#End Function
#'Prompt for storage credentials.
[String]$username = "root"
[System.Security.SecureString]$password = `
Read-Host "Please enter the password for user ""$username""" -AsSecureString
[System.Management.Automation.PSCredential]$controllerCredentials = `
New-Object System.Management.Automation.PSCredential -ArgumentList $username, $password
#'Prompt for VSC credentials.
[System.Management.Automation.PSCredential]$vscCredentials = `
#'Set variables.
[String]$controllerHostName  = "testns01"
[String]$vFilerHostName      = "testnv01"
[String]$vscHostName         = "testvc01"
[String]$protocol            = "nfs"
[Int]$dataStoreSizeGB        = 200
[String]$dataCenterName      = "Testlab"
[String]$dataStoreName       = "Datastore1"
#'Connect to the VSC using the web services API.
Try{
   Connect-VSC -VSCHostName  $vscHostName    `
               -PortNumber   $portNumber     `
               -ErrorAction  Stop
   Write-Host "Connected to VSC ""$vscHostName"" on Port ""$portNumber"""
}Catch{
   Write-Host "Failed connecting to ""$vscHostName"" on PortNumber ""$portNumber"""
   Break;
#'Resize the datastore.
Try{
   [String]$taskID = Update-VSCDataStoreSize -Connection            $connection            `
                                             -ControllerHostName    $controllerHostName    `
                                             -VFilerHostName        $vFilerHostName        `
                                             -Protocol              $protocol              `
                                             -ThinProvision         $True                  `
                                             -DataStoreName         $dataStoreName         `
                                             -DataCenterName        $dataCenterName        `
                                             -DataStoreSizeGB       $dataStoreSizeGB       `
                                             -ControllerCredentials $controllerCredentials `
                                             -VSCCredentials        $vscCredentials
   [String]$taskID = $taskID.SubString($taskID.LastIndexOf(" ") + 1)
   Write-Host "Datastore ""$dataStoreName"" resized. VCenter TaskID ""$taskID"""
}Catch{
   Write-Host "Failed Resizing datastore ""$dataStoreName"""
   Break;
Here is another example that demonstrates how to create rapid clones using the "CreateClones" method of Kamino web services API
Example output:
Enumerated Managed Object Reference for "testxp01" as "VirtualMachine:vm-17"
Enumerated Virtual Machine Files for template "testxp01"
Initiating Rapid Clones
Initiated Rapid clones. VCenter TaskID "Task:task-308"
See code below. Hope this helps
'Script Name : CreateClones.ps1
'Created     : 07/08/13
'Description : This script provides and example of creating rapid clones by
'            : invoking the "CreateClones" method of the kamino API
'            : using web services.
'Functions Section
   .SYNOPSIS
   .DESCRIPTION
   .PARAMETER
   .PARAMETER
   .EXAMPLE
   .NOTES
   Param(
         Mandatory=$True,
         Mandatory=$True,
      [Int]$PortNumber,
         Mandatory=$True,
   $connection = ""
   [String]$uri = "https://$vscHostName`:$portNumber/kamino/public/api?wsdl"
   Try{
   }Catch{
      Break;
   Return $connection;
}#End Function
   .SYNOPSIS
   Param(
         Mandatory=$True,
         Mandatory=$True,
         Mandatory=$True,
      [String]$Name,
         Mandatory=$True,
      [String]$Type,
         Mandatory=$True,
   [String]$moref     = ""
   Switch($Type){
      "Datacenter"{
      "Datastore"{
      "Folder"{
      "HostSystem"{
      "ResourcePool"{
      "VirtualMachine"{
   Return $moref;
}#End Function
Function Get-VSCVMFiles{
   .SYNOPSIS
   Param(
         Mandatory=$True,
         Mandatory=$True,
         Mandatory=$True,
      [String]$VirtualMachineName,
         Mandatory=$True,
   $files = ""
   $files = $connection.getVMFiles($VirtualMachineName, $requestSpec)
   Return $files;
}#End Function
Function Start-VSCClones{
   .SYNOPSIS
   Start-VSCClone Invokes the CreateClones Method of the Web Services API.
   .DESCRIPTION
   Creates Rapid Clones using the VSC web services API.
   .PARAMETER
   Connection Accepts a web services object containing a connection the VSC web services API.
   .PARAMETER
   VSCHostName Accepts a String containing the NetBIOS hostname of the VSC Server.
   .PARAMETER
   CloneSpec Accepts a web services object containing the clone configuration to invoke.
   .EXAMPLE
   Start-VSCClones -Connection $connection -VSCHostName "testvc01" -CloneSpec $cloneSpec -Credentials $credentials
   Param(
         Mandatory=$True,
         Mandatory=$True,
         Mandatory=$True,
      [System.Object]$CloneSpec,
         Mandatory=$True,
   $requestSpec.CloneSpec  = $cloneSpec
   #'Invoke the CreateClones Method.
      Write-Host ("Error " + $_ + " Initiating Rapid Clones") Stop
   Write-Host "Initiating Rapid Clones"
   [String]$task   = $connection.CreateClones($requestSpec)
   Return $taskID;
   Return $taskId;
}#End Function
#'Set variables.
[String]$esxHostName         = "testesx1.testlab.local"
[String]$templateName        = "testxp01"
[String]$folderName          = "netapp_rapid_clones"
[String]$customizationName   = "test1"
[Array]$cloneNames           = @("testxp10","testxp11","testxp13","testxp14","testxp15")
[Bool]$powerOn               = $False
Try{
               -ErrorAction  Stop
}Catch{
   Break;
#'Enumerate the managed object reference for the template to clone.
Try{
                                                     -Name         $dataStoreName  `
                                                     -Type         $objectType     `
                                                     -ErrorAction  Stop
   Write-Host "Enumerated Managed Object Reference for ""$dataStoreName"" as ""$dataStoreMoref"""
}Catch{
   Write-Host "Failed Enumerating Managed Object Reference for ""$dataStoreMoref"""
   Break;
Try{
   [String]$objectType    = "VirtualMachine"
   [String]$templateMoref = Get-VSCManagedObjectRef -Connection   $connection     `
                                                    -Name         $templateName   `
                                                    -Type         $objectType     `
                                                    -ErrorAction  Stop
   Write-Host "Enumerated Managed Object Reference for ""$templateName"" as ""$templateMoref"""
}Catch{
   Write-Host "Failed Enumerating Managed Object Reference for ""$templateName"""
   Break;
#'Enumerate the managed object reference for the clone destination folder.
Try{
   [String]$targetMoref = Get-VSCManagedObjectRef -Connection   $connection     `
                                                  -Name         $dataCenterName `
                                                  -Type         $objectType     `
                                                  -ErrorAction  Stop
   Write-Host "Enumerated Managed Object Reference for ""$esxHostName"" as ""$targetMoref"""
}Catch{
   Write-Host "Failed Enumerating Managed Object Reference for ""$esxHostName"""
   Break;
#'Enumerate the files for the source virtual machine template
Try{
   $files = Get-VSCVMFiles -Connection         $connection       `
                           -VirtualMachineName $templateMoref `
                           -ErrorAction Stop
   Write-Host "Enumerated Virtual Machine Files for template ""$templateName"""
}Catch{
   Break;
#'Enumerate the username and password from the controller credential object.
#'Ensure the username is correct if a local user was specified.
If($domain -ne ""){
}Else{
#'Set controller IP address (cloning only works via IP even with DNS A & PTR)
[System.Object]$controllerSpec.ipAddress          = "192.168.100.22" #$controllerHostName
[System.Object]$controllerSpec.passthroughContext = $vFilerHostName
#'Set the destination controller and datastore for the files.
ForEach($file In $files){
   $file.destDatastoreSpec.controller = $controllerSpec;
#'Create a cloneSpec Object from the NameSpace object and set properties.
[System.Object]$cloneSpecType            = ($namespace + '.cloneSpec')
[System.Object]$cloneSpec                = New-Object ($cloneSpecType)
[System.Object]$cloneSpec.templateMoref  = $templateMoref;
[System.Object]$cloneSpec.containerMoref = $targetMoref;
#'Create objects for each clone and set their properties.
[Array]$clones = @()
For($i = 0; $i -le ($cloneNames.Count -1); $i++){
   #'Create a vmSpec Object from the NameSpace object and set properties.
   [System.Object]$vmSpecType         = ($namespace + '.vmSpec')
   [System.Object]$vmSpec             = New-Object ($vmSpecType)
   #'Create a cloneSpecEntry Object from the NameSpace object and set properties.
   [System.Object]$cloneSpecEntryType = ($namespace + '.cloneSpecEntry')
   [System.Object]$cloneSpecEntry     = New-Object ($cloneSpecEntryType)
   #'Create a guestCustomizationSpecType Object from the NameSpace object and set properties.
   #'See the following VMWare KB before you apply a customization!
   #'http://kb.vmware.com/kb/1005593 (Sysprep files must be the correct version in correct location!)
   [System.Object]$guestCustomizationSpecType  = ($namespace + '.guestCustomizationSpec')
   [System.Object]$guestCustomizationSpec      = New-Object ($guestCustomizationSpecType)
   [System.Object]$guestCustomizationSpec.Name = $customizationName
   [System.Object]$vmSpec.powerOn              = $powerOn
   [System.Object]$vmSpec.custSpec             = $guestCustomizationSpec
   [System.Object]$cloneSpecEntry.key          = $cloneNames[$i]
   [System.Object]$cloneSpecEntry.Value        = $vmSpec
   [Array]$clones                             += $cloneSpecEntry
      $file.destDatastoreSpec.mor        = $dataStoreMoref;
#'Set the properties of the cloneSpec Object.
[System.Object]$cloneSpec.files  = $files
[System.Object]$cloneSpec.clones = $clones
#'Initiate the Rapid clone task for the Even Numbered Clones.
Try{
   [String]$taskId = Start-VSCClones -Connection $connection      `
                                     -CloneSpec $cloneSpec        `
                                     -ErrorAction Stop
   [String]$taskId = $taskId.SubString($taskId.LastIndexOf(" ") + 1)
   Write-Host "Initiated Rapid clones. VCenter TaskID ""$taskId"""
}Catch{
   Write-Host "Failed Initiating rapid clones"
   Break;
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
5 REPLIES 5
SCOTTS2012
Hi,
Can the above script be modified to perform a Redeploy instead of Create Clones? Have tried to modify this but cannot get it to work. If you could provide an example script on how this can be achieved I would be very grateful.
Thank you,
Scott S.
mbeattie
Hi Scott,
I understand what you're trying to do based on your post here:
https://communities.netapp.com/message/121856
In theory this should be possible as the VSC supports a "RedeployVMs" API method. EG:
[String]$ipAddress      = "192.168.100.19" #also works with FQDN EG: “testvc01.testlab.local”
Try{
}Catch{
   Break;
PS C:\> $connection.redeployVMs
MemberType          : Method
OverloadDefinitions : {string redeployVMs(Microsoft.PowerShell.Commands.NewWebserviceProxy.AutogeneratedTypes.WebServic
                      eProxy119_8143_kamino_public_api_wsdl.requestSpec arg0, Microsoft.PowerShell.Commands.NewWebservi
                      ceProxy.AutogeneratedTypes.WebServiceProxy119_8143_kamino_public_api_wsdl.controllerSpec[] arg1)}
TypeNameOfValue     : System.Management.Automation.PSMethod
Value               : string redeployVMs(Microsoft.PowerShell.Commands.NewWebserviceProxy.AutogeneratedTypes.WebService
                      Proxy119_8143_kamino_public_api_wsdl.requestSpec arg0, Microsoft.PowerShell.Commands.NewWebservic
IsInstance          : True
Having issues getting it working in my lab, might take me some time to figure out.
Matt
mbeattie
Hi Scott,
Posted the solution in your origonal thread here:
Cheers Matt
CHANDLERBING02
Hi, I have a list of non contiguous computer names in a text file.  They all use the same VM Template.  How can i use powershell to take the text file as an argument and use VSC to rapidly provision the machines in the list?
mbeattie
Hi,
Use the get-content cmdlet to read the list of hostnames from the text file instead of hardcoding the hostnames in the array. The example below assumes you will save the hostnames.txt file in the same directory as the script.
Cheers Matt
#'Read the hostnames from the text file instead of hardcoding them into an array
[String]$fileSpec   = "$scriptPath\hostnames.txt"
#[Array]$cloneNames = @("testxp10","testxp11","testxp13","testxp14","testxp15")
[Array]$cloneNames  = Get-Content -Path $fileSpec
