VMware Solutions Discussions
VSC fails to connect to vFiler "Connection Refused"
markicardy
We just introduced a new active/active system running 8.0.1P4 7-Mode.  This is in addtion to another system running 7.3.3.
So we had vFilers added into VSC 2.1 which where on the 7.3.3 system,  they where migarted to 8.0.1P4 7-Mode, everything looks good, we can still edit the resourses of the vFiler after they have moved.   Now we create a new vFiler on 8.0.1P4 7-Mode and then try to add it into VSC, this fails with the error: Cannot add storage controler "Connection Refused"
I have tried with and without SSL. I have also done a "secureadmin setup ssh" but still no luck.
As anyone seen this issue before?
1 ACCEPTED SOLUTION
costea
Did you enable the "httpd.admin.enable" option on the new vfilers?
5 REPLIES 5
ChrisHolloway
Have you also tried a secureadmin setup ssl?
Chris
markicardy
Hey Chris.
"secureadmin setup ssl " doesn't look like an option
MarkTest@KC-NAFAS32401> secureadmin setup ssl
Usage:
    secureadmin setup [-f] [-q] ssh
    secureadmin enable  all|ssh|ssh1|ssh2
    secureadmin disable all|ssh|ssh1|ssh2
    secureadmin status
costea
markicardy
That was it!  Thanks
geelsu
I started to post this in the long running thread "Re: OnCommand System Manager recieves error 500" but this one seems the better fit.  I have a FAS2240 and just finished running setup.  I configured e0a-e0d into a interface group (vif0) during setup.  I can now set at my desktop and ping the IP on both controllers.  I start OnCommand, click Add, use Credentials to enter root and the password, and then the "Hostname or IP Address" box goes red.  When I hover over the box it says "Connection Refused."   I've cut on httpd.admin.enable.  I have other FAS2240 all ready working in this OnCommand instance, though I am not the one who set up these controllers, but I have gone through the output of options and checked other system settings just to compare.  When I try and use PuTTY I get a similar message, but before I even have a chance to enter credentials so it seems to be happening pre-authentication.
What else could it be?
