VMware Solutions Discussions
What vCenter permisssions does SMVI need?
saabsimcadm
Hi,
I'm setting up SMVI 2.0 to backup vCenter 4.0 U1 to a FAS2040 and I'd like to create a special role for the SMVI user in vCenter so that SMVI doesn't have full access. What permissions does SMVI need on the vCenter server?
Thanks in advance,
Daniel
1 ACCEPTED SOLUTION
amritad
Hi,
You would need the following permissions:
·         DATASTORE
o    Remove Datastore
o    Browse Datastore
o    Remove File
o    Rename Datastore
·         HOST
o    Configuration
-       Storage Partition Configuration
-       Advanced Settings
-       Change Settings
·         VIRTUAL MACHINE
o    Interaction
-       Power off
-       Power on
o    Configuration
-       Add Existing Disk
-       Add New Disk
-       Remove Disk
-       Add or Remove Device
-       Advanced
o    State
-       Create Snapshot
-       Remove Snapshot
-       Revert to snapshot
Regards
Amrita
3 REPLIES 3
amritad
Hi,
·         DATASTORE
o    Remove Datastore
o    Browse Datastore
o    Remove File
o    Rename Datastore
·         HOST
o    Configuration
-       Advanced Settings
-       Change Settings
·         VIRTUAL MACHINE
o    Interaction
-       Power off
-       Power on
o    Configuration
-       Add Existing Disk
-       Add New Disk
-       Remove Disk
-       Advanced
o    State
-       Create Snapshot
-       Remove Snapshot
Regards
Amrita
saabsimcadm
Seems to be working well, thanks!
djaquays0
We do not use the SMVI for restores, only to take snapshots.  For us, we only had to give the SMVI user
Datastore \
  Browse Datastore
Virtual Machine \
  Configuration \
    Disk lease
  Provisioning \
    Allow read-only disk access
    Allow virtual machine download
  State \
    Create snapshot
    remove snapshot
This is the default VCB user permissions with the addition of the Browse Datastore permission, which SMVI requires.
