VMware Solutions Discussions
When VAAI NAS Plugin is installed on ESXi 5 no Copy / Sorage vMotion is possible
vMarkus_K
VMware Versions:
/ # esxcli software vib list | grep NetApp
NetAppNasPlugin                1.0-018
# vmware -vl
VMware ESXi 5.1.0 build-1117900
VMware ESXi 5.1.0 Update 1
NetApp Version:
netapp-07> version
NetApp Release 8.1.2P3 7-Mode: Wed Feb 20 19:56:22 PST 2013
Problem:
No Clone or Storage vMotion possible when VAAI NAS Plugin is installed (by vcenter or vmkfstools).
All VMs on both filer nodes are affected.
LOG of vmkfstools clone:
/vmfs/volumes/ec4e3e51-985cfc6d/TPLW2K8R2DCE_MSDN # vmkfstools -v 9 -i /vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN.vmdk /vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/bck/TPLW2K8R2DCE_MSDN.vmdk_clone
DISKLIB-VMFS  : "/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN-flat.vmdk" : open successful (285) size = 42949672960, hd = 0. Type 3
DISKLIB-VMFS  : "/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN-flat.vmdk" : closed.
DISKLIB-VMFS  : "/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN-flat.vmdk" : open successful (14) size = 42949672960, hd = 282529976. Type 3
DISKLIB-DSCPTR: Opened [0]: "TPLW2K8R2DCE_MSDN-flat.vmdk" (0xe)
DISKLIB-LINK  : Opened '/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN.vmdk' (0xe): vmfs, 83886080 sectors / 40 GB.
DISKLIB-LIB   : Resuming change tracking.
DISKLIB-LIB   : Opened "/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN.vmdk" (flags 0xe, type vmfs).
Destination disk format: Thin
Cloning disk '/vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN.vmdk'...
Failed to clone disk: The system cannot find the file specified (25).
/vmfs/volumes/ec4e3e51-985cfc6d/TPLW2K8R2DCE_MSDN # tail /vmfs/volumes/netapp-07_w2k8_000/TPLW2K8R2DCE_MSDN/TPLW2K8R2DCE_MSDN.vmdk
ddb.adapterType = "lsilogic"
ddb.thinProvisioned = "1"
ddb.geometry.sectors = "63"
ddb.geometry.heads = "255"
ddb.geometry.cylinders = "5221"
ddb.uuid = "60 00 C2 90 1b 59 bb 6e-88 36 ed 03 85 54 75 c3"
ddb.longContentID = "6f127b9a168b3d4d0fd3c3c545abcd44"
ddb.toolsVersion = "9221"
ddb.virtualHWVersion = "9"
ddb.deletable = "true"
Netapp options and stats:
netapp-07> options nfs.vstorage.enable
nfs.vstorage.enable          on
Server nfs vStorage copyoffload: (0 calls)
copy_notify    copy_revoke    copy           copy_abort     copy_status
0 0%           0 0%           0 0%           0 0%           0 0%
2 REPLIES 2
alexmattes
Hi Markus,
are you using the -actual Parameter in your /etc/exports. We had exactly the same issue when we we're using the -actual parameter with multiple directories:
Here is an example with -actual which is working:
/esx-datastore-01 -actual=/vol/esx-datastore-01/ESX,root=....
With multiple / in the actual path the plugin is not working. I think this is mentioned in the release notes or the IMT but I could find it right now.
I'm hoping that will help you with your issue.
Cheers Alex
robv
Hi,
I am also having the same issue. Customer is running 8.2P3
Anybody know if this issue is solved in 8.2.1 or 8.2.2 ?
Thanks in advance!
Rob Verhoeven
