Subscribe
esxi 5.5 and VSC 6.2 Single File Restore Problem
hello together,
what is working:
restoring an entire Maschine or Disk, but we cannot restore single files from an Backup via VSC.
When i tried to attach a disk
NETAPP VSC -> attach virtual disk i always get
No backups are available whose disk can be attached
I know that there was an option with SingleFileRestore in older versions, but attach a disk from a backup would solve my problems.
any idea how to get this working ?
We have Ubuntu and Windows Virtual Machines
thanks and regards
Re: esxi 5.5 and VSC 6.2 Single File Restore Problem
[ Edited ]
The Attach Virtual Disk option is available if you have VSC integrated with SnapCenter.
hello this is integrated in VSC 6.2 in the vSphere Administration menu
Would you explain what this means?
I'm having this same problem and the only way I'm able to perform a single file restore is to mount a backup and dig the VMDK out of the cloned datastore myself.
hi dormelchen
VSC6.2 Single file restore work with Snap Center.
you can deploy snapcenter and register VSC 6.2 with Snap Center.
check the restore logs in SnapCenter GUI-- under "Monitor".
thanks
Neeraj
