2009-08-28 12:10 AM
Our ESX3.5 scan iscsi devices and can't find any target.
vmkping is ok.
There is only a repeat error "May 7 00:46:58 ESX2 vmkiscsid[9656]: Connection to Discovery Address 192.168.10.3 failed
" and no other information in esx3.5 /var/log/messages.
The iscsi target has been found successfully by esxi3.5.
Reboot have done but the problem still.
I have allow all incoming and outgoing traffic in esx3.5 firewall.
Any ideas? tks.
2009-08-28 02:20 PM
What is the configuration of your virtual switche(s) on the ESX 3.5 server?
Since you can vmkping, I assume you have a vmkernel port. On the same virtual switch with the vmkernel port, you will need a service console port for iSCSI. This is how the ESX box establishes communication with the NetApp filer. If your vmkernel port is on a different virtual switch than your service concole (best practice), then you will need a second one.
Something like this (this is all from memory so it should be close):
First Virtual Switch:
Service Console Port with an IP address (for example 10.10.10.1)
Second Vrtual Swtich:
VMKernel Port on iSCSI network (10.10.20.1)
Service Console #2 (10.10.20.2)
The second service console isn't needed for NFS on ESX 3.5, just iSCSI. With vSphere, I have heard it isn't needed anymore but I haven't tested it.
2009-08-28 08:40 PM
As well, make sure that both the "storage" service console IP # and the "storage" vmkernel IP # can connect on a network level to the NetApp (the service console does the initial iSCSI session authentication/creation while all the storage traffic then goes over the vmkernel).
