VMware Solutions Discussions
ontap 7.3 load balance confirg mapth script error
bsrkrishna
HI 2 Every1,
I am facing majore issue while running load balance config_mpath script.
Excuted command ---->   config_mpath --primary --persistent --policy fixed --access xxxxxfas001:root:xxxxx  --access xxxxxfas002:root:xxxxx
Error:
WARNING:
   Your DNS is improperly configured.
   The following storage system hostname(s) could not be resolved:
        xxxxxfas001
       xxxxxfas002
   After the DNS issues are resolved, you must properly
   configure the preferred paths for NetApp storage systems
   by running the following command:
      /opt/netapp/santools/config_mpath --primary --loadbalance --persistent
Note: DNS  is configured properly . With same DNS entires i am able to excuted the load balancer config_mpath script in othere environment into the  same domain sucessfulluy.
Can any 1 help me out
Thanks & Regards,
BSR Krishna
5 REPLIES 5
mkopenski
Hi,
Are you able to ping the filers by name from the host? Is the firewall turned on?
I am assuming this is an esx host in which case you could install the NetApp VSC see this post  http://communities.netapp.com/message/18638
With it you can set the MPIO settings
bsrkrishna
Hi,
Thanks for quick reply. I am able to ping the FILERS. What do u mean by  NetApp VSC  and MPIO?
i am newbie for storage ...
Thanks & Regards,
BSR Krishna
bsrkrishna
HI ,
Sorry forgot to mention esx version , I am using ESX 3.5.
Thanks & Regards,
BSR Krishna
mkopenski
I think the syntax for the config_mpath command is --access <filerXX>:<password> , though I do not think that is the issue.
You also need to add the esx host to the hosts.equiv file on the filer
The format in the file is
<ESX_host>     root
If it still complains about dns, try adding the filer names/ip's the /etc/hosts on the ESX server
Mark
bsrkrishna
HI Mark,
Thnaks for quick response. i ll let u know the status by tommorw EOD.
Thanks & Regards,
BSR Krishna
