Subscribe
Accepted Solution
problems with VSC 5.0 after vCenter 5.5 minor upgrade
Hello,
a few days ago I upgraded vCenter 5.5 update 2d to 5.5 update 3b, which seems to break VSC 5.0 functionality. In vCenter web client the VSC icon is still present and most of simple tasks is working (i.e. checking for list of filers, overview of their disk usage and configuration), but if I click on "Baclup and Recovery Configuration", error box appears: "Unable to connect to Virtual Storage Console server. Please make sure that the Virtual Storage Console server is running." The server service is running, as I checked on Windows server services list. In this case as well as in some other situations like displaying the vCenter Home pane, tgere are a few new entrie in the Windows server eventlog.
Even after uninstallation and new installation of VSC 5.0 package (UAC off, elevated just in case) the problem persist. In addition, while the installation wizard and plugin registration tell it was all done successfully, it does not seem so according to the Windows event log.
Before the vCenter upgrade I checked that VSC 5.0 + vCenter 5.5 update 3 is a supported combination. It seems I cannot go on higher VSC version to test if it would work well because of old filers with older OnTAP versions, unsupported in VSC 6.0 and above.
Please, can you help me to resolve this ? Error messages from eventlog are bellow my signature.
Thanks,
  David
VSC 5.0 installation:
15285 [WrapperSimpleAppMain] WARN com.netapp.common.flow.EmbeddedDerbyPersistenceManager - FLOW-13002: Error validating embedded database tables, reloading.  Reason: Table/View 'FLOW_CONTEXT' does not exist.
25326 [WrapperSimpleAppMain] WARN com.netapp.common.flow.Engine - FLOW-10099: Exception while enabling Java Management Extensions
javax.management.InstanceAlreadyExistsException: com.netapp.common.flow:type=Threadpool,name=admin    at com.sun.jmx.mbeanserver.Repository.addMBean(Unknown Source)    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerWithRepository(Unknown Source)    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerDynamicMBean(Unknown Source)    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerObject(Unknown Source)    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.registerMBean(Unknown Source)    at com.sun.jmx.mbeanserver.JmxMBeanServer.registerMBean(Unknown Source)    at com.netapp.common.flow.Engine.enableJMX(Engine.java:355)    at com.netapp.common.flow.Engine.start(Engine.java:190)    at com.netapp.common.flow.soap.WorkflowBindingFactory.bindWorkflows(WorkflowBindingFactory.java:93)    at com.netapp.common.flow.soap.WorkflowBindingFactory.bindWorkflows(WorkflowBindingFactory.java:66)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:115)    at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:435)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:903)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:817)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)    at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)    at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)    at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)    at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)    at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:764)    at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:406)    at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:756)    at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:242)    at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1221)    at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:699)    at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:454)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:167)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:90)    at org.eclipse.jetty.server.Server.doStart(Server.java:262)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at com.netapp.common.server.AbstractJettyServer.start(AbstractJettyServer.java:142)    at com.netapp.common.server.ServerFacade.start(ServerFacade.java:60)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at com.netapp.common.cli.binding.CommandBinding.execute(CommandBinding.java:97)    at com.netapp.common.server.ServerMain.execute(ServerMain.java:45)    at com.netapp.common.server.ServerMain.main(ServerMain.java:66)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290)    at java.lang.Thread.run(Unknown Source)
44815 [WrapperSimpleAppMain] WARN org.apache.cxf.phase.PhaseInterceptorChain - Interceptor has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Remote host closed connection during handshake    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:96)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidCredential(VSphereAuthenticator.java:71)    at com.netapp.smvi.security.authentication.vsphere.VSphereCredentialVimClientLoader.loadVimClient(VSphereCredentialVimClientLoader.java:36)    at com.netapp.smvi.security.authentication.vsphere.VSphereCredentialVimClientLoader.run(VSphereCredentialVimClientLoader.java:50)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:297)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:250)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:144)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:671)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:610)    at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:412)    at org.springframework.beans.factory.annotation.InjectionMetadata.injectFields(InjectionMetadata.java:105)    at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessAfterInstantiation(AutowiredAnnotationBeanPostProcessor.java:240)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:959)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)    at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)    at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)    at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)    at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)    at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:764)    at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:406)    at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:756)    at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:242)    at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1221)    at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:699)    at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:454)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:167)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:90)    at org.eclipse.jetty.server.Server.doStart(Server.java:262)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at com.netapp.common.server.AbstractJettyServer.start(AbstractJettyServer.java:142)    at com.netapp.common.server.ServerFacade.start(ServerFacade.java:60)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at com.netapp.common.cli.binding.CommandBinding.execute(CommandBinding.java:97)    at com.netapp.common.server.ServerMain.execute(ServerMain.java:45)    at com.netapp.common.server.ServerMain.main(ServerMain.java:66)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    ... 111 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 112 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 127 more
44842 [WrapperSimpleAppMain] ERROR com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator - Incorrect password
javax.xml.ws.soap.SOAPFaultException: Remote host closed connection during handshake    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:147)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidCredential(VSphereAuthenticator.java:71)    at com.netapp.smvi.security.authentication.vsphere.VSphereCredentialVimClientLoader.loadVimClient(VSphereCredentialVimClientLoader.java:36)    at com.netapp.smvi.security.authentication.vsphere.VSphereCredentialVimClientLoader.run(VSphereCredentialVimClientLoader.java:50)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:297)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:250)    at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:144)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)    at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:671)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:610)    at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:412)    at org.springframework.beans.factory.annotation.InjectionMetadata.injectFields(InjectionMetadata.java:105)    at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessAfterInstantiation(AutowiredAnnotationBeanPostProcessor.java:240)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:959)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)    at java.security.AccessController.doPrivileged(Native Method)    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)    at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)    at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)    at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)    at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)    at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:764)    at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:406)    at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:756)    at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:242)    at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1221)    at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:699)    at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:454)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:167)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:224)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:90)    at org.eclipse.jetty.server.Server.doStart(Server.java:262)    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)    at com.netapp.common.server.AbstractJettyServer.start(AbstractJettyServer.java:142)    at com.netapp.common.server.ServerFacade.start(ServerFacade.java:60)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at com.netapp.common.cli.binding.CommandBinding.execute(CommandBinding.java:97)    at com.netapp.common.server.ServerMain.execute(ServerMain.java:45)    at com.netapp.common.server.ServerMain.main(ServerMain.java:66)    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)    at java.lang.reflect.Method.invoke(Unknown Source)    at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    ... 104 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 112 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 127 more
Ending a Windows Installer transaction: C:\Users\komanek\AppData\Local\Downloaded Installations\{EBAD5B22-B50A-4784-84E5-0DF936505EAA}\NetApp® Virtual Storage Console for VMware vSphere.msi. Client Process Id: 12456.
Product: NetApp® Virtual Storage Console 5.0 for VMware vSphere -- Installation operation completed successfully.
Windows Installer installed the product. Product Name: NetApp® Virtual Storage Console 5.0 for VMware vSphere. Product Version: 5.0.2967.0. Product Language: 1033. Manufacturer: NetApp, Inc. Installation success or error status: 0.
working with vCenter web client:
1582786 [qtp1829193464-307] WARN org.apache.cxf.phase.PhaseInterceptorChain - Interceptor has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Remote host closed connection during handshake    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:96)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidSession(VSphereAuthenticator.java:44)    at com.netapp.smvi.security.authentication.handler.VSphereAuthenticationHandler.authenticate(VSphereAuthenticationHandler.java:27)    at com.netapp.smvi.security.authentication.AuthenticationChainManager.authenticate(AuthenticationChainManager.java:39)    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:75)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    ... 55 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 56 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 71 more
1582789 [qtp1829193464-307] ERROR com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator - Failed to authenticate vSphere sessionId %s
javax.xml.ws.soap.SOAPFaultException: Remote host closed connection during handshake    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:147)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidSession(VSphereAuthenticator.java:44)    at com.netapp.smvi.security.authentication.handler.VSphereAuthenticationHandler.authenticate(VSphereAuthenticationHandler.java:27)    at com.netapp.smvi.security.authentication.AuthenticationChainManager.authenticate(AuthenticationChainManager.java:39)    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:75)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    ... 48 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 56 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 71 more
1583247 [qtp1829193464-307] WARN org.apache.cxf.phase.PhaseInterceptorChain - Interceptor has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Remote host closed connection during handshake    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:96)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidCredential(VSphereAuthenticator.java:71)    at com.netapp.smvi.security.authentication.handler.VSphereAuthenticationHandler.authenticate(VSphereAuthenticationHandler.java:33)    at com.netapp.smvi.security.authentication.AuthenticationChainManager.authenticate(AuthenticationChainManager.java:39)    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:75)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    ... 55 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 56 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 71 more
1583253 [qtp1829193464-307] ERROR com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator - Incorrect password
javax.xml.ws.soap.SOAPFaultException: Remote host closed connection during handshake    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:147)    at com.sun.proxy.$Proxy87.retrieveServiceContent(Unknown Source)    at com.netapp.smvi.VimClient.<init>(VimClient.java:64)    at com.netapp.smvi.VimClientFactory.getVimClient(VimClientFactory.java:105)    at com.netapp.smvi.security.authentication.vsphere.VSphereAuthenticator.isValidCredential(VSphereAuthenticator.java:71)    at com.netapp.smvi.security.authentication.handler.VSphereAuthenticationHandler.authenticate(VSphereAuthenticationHandler.java:33)    at com.netapp.smvi.security.authentication.AuthenticationChainManager.authenticate(AuthenticationChainManager.java:39)    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:75)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: com.ctc.wstx.exc.WstxIOException: Remote host closed connection during handshake    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)    at org.apache.cxf.interceptor.AbstractOutDatabindingInterceptor.writeParts(AbstractOutDatabindingInterceptor.java:94)    at org.apache.cxf.interceptor.BareOutInterceptor.handleMessage(BareOutInterceptor.java:68)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:472)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:302)    at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:254)    at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)    at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:127)    ... 48 moreCaused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)    at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)    at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleHeadersTrustCaching(HTTPConduit.java:1913)    at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.onFirstWrite(HTTPConduit.java:1868)    at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:42)    at org.apache.cxf.io.AbstractThresholdOutputStream.write(AbstractThresholdOutputStream.java:69)    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:96)    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)    ... 56 moreCaused by: java.io.EOFException: SSL peer shut down incorrectly    at sun.security.ssl.InputRecord.read(Unknown Source)    ... 71 more
1583259 [qtp1829193464-307] ERROR com.netapp.smvi.security.PasswordHandler - Incorrect password
1583260 [qtp1829193464-307] WARN org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor -
org.apache.ws.security.WSSecurityException: The security token could not be authenticated or authorized; nested exception is:     org.apache.ws.security.WSSecurityException: Incorrect password    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:165)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: org.apache.ws.security.WSSecurityException: Incorrect password    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:76)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    ... 40 more
1583263 [qtp1829193464-307] WARN org.apache.cxf.phase.PhaseInterceptorChain - Interceptor has thrown exception, unwinding now
org.apache.cxf.binding.soap.SoapFault: The security token could not be authenticated or authorized; nested exception is:     org.apache.ws.security.WSSecurityException: Incorrect password    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.createSoapFault(WSS4JInInterceptor.java:445)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:289)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:66)    at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:236)    at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:104)    at org.apache.cxf.transport.servlet.ServletDestination.invoke(ServletDestination.java:99)    at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:350)    at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:182)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.invoke(AbstractCXFServlet.java:163)    at org.apache.cxf.transport.servlet.AbstractCXFServlet.doPost(AbstractCXFServlet.java:141)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)    at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)    at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)    at org.eclipse.jetty.server.Server.handle(Server.java:350)    at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)    at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:47)    at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)    at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)    at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)    at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)    at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:66)    at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:254)    at org.eclipse.jetty.server.ssl.SslSocketConnector$SslConnectorEndPoint.run(SslSocketConnector.java:665)    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)    at java.lang.Thread.run(Unknown Source)Caused by: org.apache.ws.security.WSSecurityException: The security token could not be authenticated or authorized; nested exception is:     org.apache.ws.security.WSSecurityException: Incorrect password    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:165)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleToken(UsernameTokenProcessor.java:56)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:326)    at org.apache.ws.security.WSSecurityEngine.processSecurityHeader(WSSecurityEngine.java:243)    at org.apache.cxf.ws.security.wss4j.WSS4JInInterceptor.handleMessage(WSS4JInInterceptor.java:179)    ... 36 moreCaused by: org.apache.ws.security.WSSecurityException: Incorrect password    at com.netapp.smvi.security.PasswordHandler.handle(PasswordHandler.java:76)    at org.apache.ws.security.processor.UsernameTokenProcessor.handleUsernameToken(UsernameTokenProcessor.java:160)    ... 40 more
Re: problems with VSC 5.0 after vCenter 5.5 minor upgrade
Well, I finally resolved it using instructions from
http://community.netapp.com/t5/VMware-Solutions-Discussions/VSC-5-0-SSL-Handshake-Failures/m-p/16572/thread-id/1682/highlight/false
It was hard for me to find it so I asked too eraly here. At least, there are details from eventlog in my post, hopefuly it can help somebody else finding the final info.
Thanks for patience,
  David
I have a similar issue, I'm using the vCenter 5.5 appliance, doing a fresh deployement, I've updated the appliance to U3
 5.5.0.30200 Build 3255668
I had VSC 5.0P1 and found that VSC 5.x is no longer even available on the Netapp download support site, only the 4.2.2
I can't even get the plugin to show in the vsphere web client.
It registers successfully, I see the plugin listed in the windows based VSphere client, but no plugin!  Why The Face?
After reviewing this I too modified the additional options, I had to add it to the end change the number 5 to number 8 and put it at the end of the list of options, restarted the VSC service, reregistered with vcenter and rebooted vcenter appliance and it worked
Line modified in \program files\netapp\virtual storage console\wrapper\wrapper.conf
 wrapper.java.additional.5=-Dhttps.protocols=TLSv1
