VMware Solutions Discussions
using or reserving 98% of space and 0% of inodes, using 98% of reserve
TDUBB1234
I am getting this warning from dfm
Global Status: NonCritical; /vol/dr_esx_vol2_sr is full (using or reserving 98% of space and 0% of inodes, using 98% of reserve).
aggr show_space -h
Volume                                Allocated            Used       Guarantee
dr_esx_vol2_sr                     1371GB          1366GB            none
df -V -g -h
Filesystem               total             used            avail       capacity   Mounted on
/vol/dr_esx_vol2_sr/     1380GB     1349GB       30GB      98%        /vol/dr_esx_vol2_sr/
rw-ntap2> vol options dr_esx_vol2_sr
nosnap=on, nosnapdir=on, minra=off, no_atime_update=off, nvfail=off,
ignore_inconsistent=off, snapmirrored=off, create_ucode=off,
convert_ucode=off, maxdirsize=45875, schedsnapname=ordinal,
fs_size_fixed=off, compression=off, guarantee=none, svo_enable=off,
svo_checksum=off, svo_allow_rman=off, svo_reject_errors=off,
no_i2p=off, fractional_reserve=0, extent=off, try_first=volume_grow,
read_realloc=off, snapshot_clone_dependency=off, nbu_archival_snap=off
snap reserve
Volume dr_esx_vol2_sr: current snapshot reserve is 0% or 0 k-bytes.
snap list
working...
  %/used       %/total  date          name
24% (24%)   21% (21%)  Oct 29 08:01  hourly.0
25% ( 2%)   23% ( 2%)  Oct 29 00:01  nightly.0
28% ( 5%)   26% ( 4%)  Oct 28 20:01  hourly.1
28% ( 1%)   27% ( 1%)  Oct 28 16:00  hourly.2
29% ( 0%)   27% ( 0%)  Oct 28 12:00  hourly.3
29% ( 0%)   28% ( 0%)  Oct 28 08:00  hourly.4
30% ( 2%)   29% ( 2%)  Oct 28 00:00  nightly.1
30% ( 0%)   29% ( 0%)  Oct 27 20:00  hourly.5
and then in vmware the lun shows as normal status
1.27TB and 347.39GB Free
any idea?
1 REPLY 1
TDUBB1234
just found out my df -r -h shows
/vol/dr_esx_vol2_sr/     1380GB     1349GB       30GB        0GB  /vol/dr_esx_vol2_sr/
snap reserve               0GB      404GB        0GB        0GB  /vol/dr_esx_vol2_sr/..
so my snapshots are using 404GB?
