AFF
LIF FOR SAN (ONTAPP)
Arz
Dear All,
please help me for create Lif for SAN.
we have connected 2FC port each node. I created SVM and enabled FC Protocol.
I did not created Lif for FC. kindly advise below cmd is fine or not (What is recommendation for LIF )
which wwwn i will use for zone?
network interface create -vserver svm01 -lif lif01 -role data -data-protocol fcp -home-node node01 -home-port 2a
network interface create -vserver svm01 -lif lif02 -role data -data-protocol fcp -home-node node01 -home-port 2b
network interface create -vserver svm01 -lif lif03 -role data -data-protocol fcp -home-node node02 -home-port 2a
network interface create -vserver svm01 -lif lif02 -role data -data-protocol fcp -home-node node02 -home-port 2b
1 ACCEPTED SOLUTION
SpindleNinja
each will have it's own.   the physical target ports will have wwpns that start with 50:   the lifs will start with 20:
8 REPLIES 8
SpindleNinja
you'll want to zone to the WWPN that is generated with the LIF.
Arz
Dear SpindleNinja,
every LIF interface  has own wwpn? or single wwpn?
SpindleNinja
Arz
Thank You, is Below cmd correct for lif configuration
SpindleNinja
That looks right.   I think you can also do it from the GUI?
if you haven't seen it. this set of docs might be helpful for you. https://docs.netapp.com/us-en/ontap/san-admin/index.html
Arz
Thanks I didnt find the option on GUI.
ONE more question....
do we need to create one LIF for  One fc physcial port?
do we need to create one LIF for  multiple  physcial fc port (group physical port)?
SpindleNinja
One per active FC port - per SVM.
Arz
Thank you 😍
