Additional Virtualization Discussions
Cannot create SR in XenServer 5.6 SP2 using Advanced StorageLink Technology
THOLWERDA
We recently had our FAS3210 installed and are now attempting to attach it to our XenServer 5.6 environment.  I believe I'm correct in that the interface group type is lacp (even though when we run setup, it shows m.  We've modified, rebooted and it still shows m).  Our switch environment consists of (5) 3750 running 12.2.  The switch configuration is as follow:
interface Port-channel31
switchport access vlan 193
switchport mode access
end
interface GigabitEthernet5/0/14
description ***NetApp Ctrl1 E0A***
no cdp enable
channel-protocol lacp
channel-group 31 mode active
end
interface GigabitEthernet5/0/15
description ***NetApp Ctrl1 E0B***
no cdp enable
spanning-tree portfast
end
Within XenCenter, we attempt to create a new SR.  We select Advanced StorageLink technology, provide a name and select NetApp as the storage system, provide the IP of the network interface storage group, use the same username/password as we use to access the controller via SSH and then I get the following error:
Scanning NetApp filer 10.1.93.50 for existing SRs...
Failed to connect to Netapp target
Check your settings and try again.
Ideas anyone?
5 REPLIES 5
wallwraadm
solved?
NICKDROGO
Were you able to get this to work and how.  We are running Xen 5.5 and Data ontap 8 and cant get Advanced Storage Link to work.  Is there any setup guides
crocker
is this one that your team handles or should the question be asked in the NetApp Support Community?
dubois
crocker
Looks like you were not able to help on this issue here.  We have external and internal subject matter experts in the NetApp Support Community answering questions about Filers.  If you have a NOW login, this link enables you to engage them about this.
