Cloud Articles and Resources
Data ONTAP PowerShell Toolkit - Chart controller performance
cknight
views-count 8291 Views
Monitoring storage controller performance, or diagnosing a performance issue, is simplified by starting with a high-level picture of controller metrics to determine where to focus (i.e. I/O demand, CPU bottlenecks, controller latency, network or disk traffic).  The attached script leverages the Data ONTAP PowerShell Toolkit, the Windows Forms API, and the Google Chart API to create controller performance graphs.  The graphs scale dynamically, update every 20 seconds, and display one hour of data.  The host running the script must have Internet connectivity.  Toolkit 1.2 is required.
Example:
PS C:\> Show-NaPerf.ps1 dunn
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
Replies
sjasupport
Thanks.  This looks like a great script and something I will definately be using to monitor the performance of the filers in our enviroment.
For NetApp novices, links to performance troubleshooting guides would be useful to have as well on this post.
slrstordata
hello.
does this PowerShell script work with NetApp toolkit v3.0 ?
i have crazy graph results.....
slrstordata
problem is linked to Windows OS Regional settings parameters.....
with English date format, working better than with french setting
PHILIPALBERT
Hi,
Does your script support Cluster-Mode or only 7-mode?
Thanks
All Community Forums
