Cloud Articles and Resources
Data ONTAP PowerShell Toolkit - HOWTO: Work with LUNs and Qtrees
fjohn
When creating LUNs, it’s generally a best practice to place them in Qtrees.  Fortunately, it’s easy to create Qtrees with Data ONTAP PowerShell Toolkit; just use the New-NaQtree cmdlet:
New-NaQtree /vol/vol1/qt_vol1
Creates a Qtree called “qt_vol1” in the volume “vol1”
Now with the Qtree out of the way, it’s time to create a LUN.  Sure, we could use the toolkit to create a LUN filer side, create an igroup and map it, then rescan the disks (that’s  “rescan” | diskpart  in PowerShell BTW), but then you’d have to give it a drive letter and format it and otherwise do a lot of work.  It’s far easier to just create the LUN using the SnapDrive CLI right from within your PowerShell script.  You’d do something like:
Sdcli disk create –d I:\ -p /vol/vol1/test.lun  -z 10240 –dtype dedicated –rs n –IG MyLaptop igroup_iscsi
This creates a 10GB LUN in vol1 and attaches it as drive I:\ to my laptop via iSCSI with no space reserved for snapshots.  Oops.  I forgot all about that best practice of putting LUNs in Qtrees.  Not to worry; you can use the Rename-NaLun cmdlet to move a LUN
Rename-nalun /vol/vol1/test.lun /vol/vol1/qt_vol1/test.lun
Not a problem.
Well, I just created a Thick LUN.  What if I wanted to thin it?  Easy:
Set-nalunspacereserved /vol/vol1/qt_vol1/test.lun –off
It’s a thin LUN now.  While I’m at it, I’ll enable Dedupe on the volume:
Enable-NaSiS /vol/vol1
John
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
Replies
DAVID_PUCKETT_KAREO
Is there a better/native way to do the SLCI command with the latest powershell toolkit?
vinith
You can do that with
Invoke-Nassh "<sdcli cmd>"
You can get detailed help for this cmdlet using
PS C:\Users\vinith> Get-Help Invoke-NaSsh -Detailed
An example below.
C:\PS>Connect-NaController dunn
C:\PS> Invoke-NaSsh aggr status
VKALVEMULA
hi John
i have few 1 tb luns that i would like to move into a separate qtrees
is "lun move" command non disruptive ?
sizemore
Yes it's non disruptive, but I would use the toolkit.
VKALVEMULA
i created a lun (5gb) and moved into a qtree (2gb).
but the writes did not stop when qtree was full, even tough i did set up hard limit as 2gb.
how can i setup in such a way that when qtree is full, it shouldnt accept any more writes and accept only reads.
All Community Forums
