In the NetApp storage model, the basic unit is the RAID group. RAID groups are combined into pools called Aggregates. Logical containers called Flexvols are carved from the space in an aggregate. A Flexvol can contain files or LUNs. Further, a Flexvol can be partitioned by creating Qtrees in it.
If you’ve worked with QSM or SnapVault, then you’re probably familiar with one use case for Qtrees in conjunction with LUNs. Qtrees are also common in NFS or CIFS file environments. Like a directory, a Qtree can be used to further partition space within a volume that contains files. In these Environments, Qtrees are often used in conjunction with Quotas.
There are three basic types of Quota; the tree, user, and group quota. A quota can be applied to a volume or a Qtree. In addition a default quota can be applied to an object, which also applies to all objects beneath the object to which it is applied. Through quotas, you can set hard, soft, or threshold limits on the number of files of amount of disk space consumed. A threshold quota is a unique case. In addition to logging, a threshold quota will send an SNMP trap.
The Data ONTAP PowerShell Toolkit provides several cmdlets for manipulating quotas. Foremost among them is add-naquota. To add a default tree quota to the volume vol1, with a DiskLimit of 10GB,
Add-naquota tree * vol1 –DiskLimit 10g
To add a threshold limit of 7GB to the qtree qtree_1 in the volume vol1,
Add-naquota tree /vol/vol1/qtree_1 vol1 –Threshold 7g
To remove the quota from the qtree qtree_1,
Remove-naquota tree /vol/vol1/qtree_1 vol1
To get a report of all quotas,
Get-naquotareport
In addition to working with files if you place your LUNs in qtrees, and then place a quota on the qtree, things start to get real interesting.
More to follow.
Happy Scripting
J
