So my lab has a good number of controllers and my Boss walked in and wanted to know specifically where the FlexCache Cards we installed at located. Can I write a quick and dirty script to discover all the controllers in the lab, log onto each one using one of two default passwords, then find out if a FlexCache controller exists in each one.
An hour later this emerged. Its pretty rough, but it works well. I put in code to make sure the login was successful, as well as modified the output colors to make sure its fast to read the output.
function FindFlashDevice
{ if (get-naflashdevice -erroraction silentlycontinue)
{ $size=(get-naflashdevice).capacity/1024/1024/1024
Write-host "Found a Flash Device of size "$size"GB." -foregroundcolor green
else
{ write-host " - - No Flash Device Found" -foregroundcolor gray
function ScanSubnet($IPAddr, $SubNetMask)
{ Write-host "Scanning Subnet "$IPAddr" with mask "$SubNetMask
foreach($controller in find-nacontroller $IPAddr $SubNetMask)
{ write-host " - Found Controller "$Controller.name
if (Connect-NAController ($controller.address).ipaddresstostring –cred $cred1 -erroraction silentlycontinue)
{ write-host " - - Connected using First Credentials" -foregroundcolor gray
FindFlashDevice
else
{ if (Connect-NAController ($controller.address).ipaddresstostring –cred $cred2 -erroraction silentlycontinue)
{ write-host " - - Connected using second credentials" -foregroundcolor gray
FindFlashDevice
else
{ write-host "Unable to connect to controller" -foregroundcolor red
$pass1=ConvertTo-SecureString “secretpassword” –AsPlainText –Force
$pass2=ConvertTo-SecureString “othersecretpassword” –AsPlainText –Force
$cred1=New-Object –TypeName System.Management.Automation.PSCredential –Argumentlist “root”,$pass1
$cred2=New-Object –TypeName System.Management.Automation.PSCredential –Argumentlist “root”,$pass2
Write-host "---------------"
Write-host "Starting Script"
ScanSubnet "10.50.88.0" "255.255.255.0"
ScanSubnet "10.60.92.0" "255.255.252.0"
ScanSubnet "10.70.99.0" "255.255.255.0"
The output of the script looks like this.
I am sure I could do much more complex tasks, but this script shows how you can scan a farm of NetApp controllers.
Chris Lionetti
