Cloud Volumes
Problem backing up critical volumes on 2008 SBS
NoelBlakley
Hello,
I have a problem to do a Windows System Backup on Windows 2008 SBS. Server has two volumes, "C" for system and "E" for mass data. If I configure the backup with option "include all critical volumes" which is needed to be able to do a bare-metal restore, I get the error "not enough space on disk for backup" (sorry if the translation is not exact). Log shows Cloudbacko is trying to do a backup of C: and E:, reason of why is not enough space. I have checked in Cloudbacko config that E is not marked for backup. If I uncheck critical volumes option, only C is backed up and correctly.
How can I backup only C for bare-metal restore?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
**removed by moderator**
Thank you.
Earn Rewards for Your Review!
GPI Review Banner
All Community Forums
