Converged Infrastructure Discussions
Highlighted
NetApp FAS2240 FC connection to Cisco UCS 220M3
Hello,
we have a FAS2240-2 FC and we need to connect it to Cisco UCS 220 M3, what we need are FC cards.
We found LPe12002 on e-bay.
Question is, would they help us to make direct connection between FAS2240-2 and Cisco UCS 220 M3??
Best regards,
1 REPLY 1
Highlighted
Re: NetApp FAS2240 FC connection to Cisco UCS 220M3
By definition, the Fibre Channel cards enable connectivity from the storage array to the host.  I think you want to confirm support on the NetApp IMT:
NetApp Interoperability Matrix Tool (IMT)
and also ensure you're getting equipment from a relaible source.  You can consider buying from NetApp or a partner who not only resell our products but provide valuable guidance and services in how to use them:  http://www.netapp.com/us/how-to-buy/
Try the NEW Knowledgebase!
NetApp KB Site
Forums
