Hi,
Is there any documentation specific to snapcreator and Oracle on Linux or can someone who has a better understanding of how to configure snapcreator help me through this please? I am trying to get snapcreator to take snapshots of my oracle DB and vault it to another array. I went through the gui wizard to configure a basic file and it's not working. Below is the output of my failed attempt:
[Mon Dec 10 15:20:43 2012] INFO: Logfile timestamp: 20121210152043
[Mon Dec 10 15:20:43 2012] INFO: Plugin validation skipped for oracle, no plugin parameters file found or no parameters set
########## Parsing Environment Parameters ##########
########## PRE APPLICATION QUIESCE COMMANDS ##########
[Mon Dec 10 15:20:43 2012] INFO: No commands defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## Application quiesce ##########
[Mon Dec 10 15:20:49 2012] [orcyrac1:9090(3.6.0.1)] INFO: Quiescing databases
[Mon Dec 10 15:20:49 2012] [orcyrac1:9090(3.6.0.1)] INFO: Quiescing database orcy
[Mon Dec 10 15:20:49 2012] [orcyrac1:9090(3.6.0.1)] ERROR: [ora-00020] Oracle SQL*Plus command [/bin/su - oracle -c "ORACLE_HOME=/opt/oracle/product/10.2/;export ORACLE_HOME;ORACLE_SID=orcy;export ORACLE_SID;/opt/oracle/product/10.2/bin/sqlplus /nolog @/tmp/UWnSRTKKFZ.sc"] failed with return code [0] and message [The Oracle base for ORACLE_HOME=/opt/oracle/product/10.2 is /opt/oracle/product/10.2
SQL*Plus: Release 10.2.0.5.0 - Production on Mon Dec 10 15:20:49 2012
Copyright (c) 1982, 2010, Oracle. All Rights Reserved.
Connected to an idle instance.
select * from v$version
ERROR at line 1:
ORA-01034: ORACLE not available
Disconnected
[Mon Dec 10 15:20:49 2012] [orcyrac1:9090(3.6.0.1)] ERROR: [ora-00001] Verifying correct version of database orcy failed
[Mon Dec 10 15:20:47 2012] [orcyrac1:9090(3.6.0.1)] ERROR: [scf-00053] Application quiesce for plugin oracle failed with exit code 1, Exiting!
########## Application unquiesce ##########
[Mon Dec 10 15:20:53 2012] [orcyrac1:9090(3.6.0.1)] INFO: Unquiescing databases
[Mon Dec 10 15:20:53 2012] [orcyrac1:9090(3.6.0.1)] INFO: Unquiescing database orcy
[Mon Dec 10 15:20:53 2012] [orcyrac1:9090(3.6.0.1)] ERROR: [ora-00010] Ending hot backup mode for database orcy failed
[Mon Dec 10 15:20:49 2012] ERROR: [scf-00054] Application unquiesce for plugin oracle failed with exit code 1, Exiting!
########## PRE EXIT COMMANDS ##########
[Mon Dec 10 15:20:49 2012] INFO: No commands defined
########## PRE EXIT COMMANDS FINISHED SUCCESSFULLY ##########
I am attaching my configuration file as well for reference. As you can see, it's not even connecting to the oracle database, orcy, but once I get past that point, how does it take the snapshots? Do I need to specify additional information for snapdrive to take the snapshot since the server uses lun? Any help someone can provide is greatly appreciated.
Thanks
Michael
