Data Backup and Recovery
%MSG seems to not work with SnapCreator 4.0P1 on linux
f_duranti
Hi, I've a problem to make the %MSG work with sendtrap.
This is a simple configuration, it seems that %MSG is not working either with SENDTRAP that with SUCCESS_TRAP
SUCCESS_MSG=SUCCESS
NTAP_ASUP_ERROR_ENABLE=N
SENDTRAP=/bin/echo ERROR %CONFDIR %CONFNAME %SNAP_TYPE %ACTION %SNAME %SNAP_TIME - %MSG - %SUCCESS_MSG
SUCCESS_TRAP=/bin/echo OK %CONFDIR %CONFNAME %SNAP_TYPE %ACTION %SNAME %SNAP_TIME - %MSG - %SUCCESS_MSG
%MSG is just reporting the string "MSG"
This is an example with a backup error:
########## Snap Creator Framework 4.0p1 failed ##########
[Wed Oct 2 17:33:26 2013] INFO: Pre Exit commands are not defined. Skipping !
[Wed Oct 2 17:33:26 2013] INFO: Sending Trap message to external system /bin/echo ERROR FS_Share itromfsv02 hourly backup BCK 20131002173325 - MSG - SUCCESS
[Wed Oct  2 17:33:31 2013] INFO: stdout:ERROR FS_Share itromfsv02 hourly backup BCK 20131002173325 - MSG - SUCCESS
[Wed Oct  2 17:33:31 2013] ERROR: NetApp Snap Creator Framework 4.0p1 CLI action backup failed
This is an example with a backup without errors:
########## Snap Creator Framework 4.0p1 finished successfully ##########
[Wed Oct 2 17:36:55 2013] INFO: SUCCESS
[Wed Oct 2 17:36:55 2013] INFO: Sending Trap message to external system /bin/echo OK FS_Share itromfsv02 hourly backup BCK 20131002173420 - MSG - SUCCESS
[Wed Oct  2 17:36:56 2013] INFO: stdout:OK FS_Share itromfsv02 hourly backup BCK 20131002173420 - MSG - SUCCESS
1 ACCEPTED SOLUTION
sivar
Dear Francesco,
I am afraid, this is a bug.
I was able to reproduce this in the lab.
I will request the developers to take a look at this and get back to you in couple of days.
If you want to track this using a support case, I would recommend register a NetApp support case.
Thanks,
Siva Ramanathan
Snap Creator Community Moderator
4 REPLIES 4
sivar
Dear Francesco,
Thanks,
Siva Ramanathan
f_duranti
Thanks Siva, I've posted it on snapcreator dev community.
branislav_neskovic
Hi Siva,
Is there any news about this bug? I have the same issue on SC 4.0P1 Windows installation.
Best regards,
Bane
sivar
Hello Bane,
Last I remember is this has been fixed (but with few limitations around what variables can be passed).
Let me check this in the lab real quick and get back to you.
I have received your scdump from the other thread, and will look into that shortly.
Thanks,
Siva Ramanathan
