Data Backup and Recovery
Problem and Concern install SnapCenter Plug-in for VMware vSphere
kiyomits
I have installed SnapCenter 3.0 Plugin for VM. But when adding resource, It occerred error attached files. It shows the following log.
"ERROR VSC com.netapp.aegis.sms.util.SnapManagerServiceHelper SnapCenter Server is not configured yet for SCV plugin. Please check scbr.properties."
Does anyone know the cause?
And, about vcenter server, do you know the VM plugin support on both vcenter appliance and on windows.
I concern plugin support only on windows.
1 ACCEPTED SOLUTION
kiyomits
I could connect snapcenter vmplugin on windows vcenter.
But I dont know when add host for vm plugin under vcenter appliance on linux like attached file.
Only users of windows can be selected.
Do you know how to register? Are there any conditions?
3 REPLIES 3
spinks
From what I understand the vCenter appliance is supported.
I have not seen the error you reference.  The best thing to do is open a support case so they can gather and review the appropriate logs.
John
kiyomits
I resolved this problem. I have to migrate VSC to SnapCenter at first.
kiyomits
