Data Backup and Recovery
Problem with SMO 3.3.0
GIE_CODELOG
Hello,
I have a problem with SMO on a RedHat Linux ES 5 x64 with SMO 3.3.0.
My scheduled backup does not launch anymore. Here is the log I received :
Status
FAILED
Warning Messages
[WARN] FLOW-11011: Operation aborted
Error Messages
SMO-13032: Cannot perform operation: Backup Create. Root cause: SMO-11004: Error creating Snapshot copy: EXE-00002: Timeout of 0:05:00.000 occurred while executing command: /usr/sbin/snapdrive snap create -fs /oraxxx/yyy -fs -snapname smo_yyy_20130221_150557_1_d992a4943cfd131b013cfd13212a0001_0 -unrelated
This has been caused by a power failure, SMO was doing the backup when the failure appears...
I have restarted the smo_server without success...
I have others databases than this one, everything is ok with them.
Thanks for your help.
1 REPLY 1
atarakanov
Hello, check name resolutions. In my case the error appears during primary DNS server maintenance. After primary  DNS server was up the error disappears.
