Data Backup and Recovery
Snapdrive snap restore fails to mount NFS volume
MKELLYSCSC
Hi
we have been testing SnapDrive 5.3 for Linux and CDOT 8.3.1P1.
The server OS is RHEL 6.4.
We have discovered that snapdrive snap restore fails when using NFS mounted volumes.
It looks like snapdrive initially unmounts the filesystem and then tries to mount it on a mountpoint created in the /tmp directory.
The command that is invoked looks like
mount -t <filer:/volume> /tmp/SDU_<datetimestamp>_<pid>
This fails because the fs type is not specified.
I ran the command using strace and I cannot see any attempt to determine the fstype.
Is this a bug or a configuration issue?
Thanks.
1 ACCEPTED SOLUTION
MKELLYSCSC
Turns out that the problem was down to the way the snapdrive command was structured.
We were doing:
snapdrive snap restore -fs /path/to/filesystem -snapname <SVMname>:/path/to/volume:snap_name
It should be:
snapdrive snap restore -fs /path/to/filesystem -snapname snap_name
3 REPLIES 3
Sahana
Hi,
It could be because of bug http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=826616
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
MKELLYSCSC
Hi Sahana,
the problem is not related to the bug you referred to:
We have both A and PTR records for the LIF used to access the volume and the SVM that owns the volume.
The error message we get is:
0002-890 Admin error: Error mounting temp directory /tmp/SDU_05202016_122529_7049: Unexpected error from mount:
this is followed by the mount 'usage' output.
It looks like snapdrive is unable to determine the mount type (in this case 'nfs').
MKELLYSCSC
We were doing:
It should be:
