Data Backup and Recovery
[ltd-00002] Quiescing databases finished with errors
shultgren
A fresh install of Windows 2008 R2, Lotus Domino 8.5.33
I do not get the Domino Plug-in to work at all. Below are the errors in my log:
[2013-12-05 14:39:16,628] INFO: Agent validation completed successfuly for agent localhost:9090
########## Plugin validation ##########
[2013-12-05 14:39:16,691] INFO: Plugin validation completed successfuly for plugin domino
########## PRE APPLICATION QUIESCE COMMANDS ##########
[2013-12-05 14:39:16,691] INFO: Pre application quiesce commands are not defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY  ##########
[2013-12-05 14:39:16,691] INFO: Application auto discovery is not enabled skipping .
[2013-12-05 14:39:16,691] INFO: Validate volume is not enabled skipping validate volume task.
########## Application Quiesce ##########
[2013-12-05 14:39:17,152] DEBUG: [localhost:9090 (4.0.0.1)] domino::setENV finished successfully
[2013-12-05 14:39:17,152] INFO: [localhost:9090 (4.0.0.1)] Quiescing databases
[2013-12-05 14:39:17,152] DEBUG: [localhost:9090 (4.0.0.1)] Calling dominocore::quiesce with arguments(D:\notes\notes.ini,D:\notes\data,C:\notes\changeinfo,0 )
[2013-12-05 14:39:17,152] INFO: [localhost:9090 (4.0.0.1)] No Errors encountered while opening DBs.
[2013-12-05 14:39:17,152] ERROR: [localhost:9090 (4.0.0.1)] [ltd-00002] Quiescing databases finished with errors
[2013-12-05 14:39:17,152] ERROR: [localhost:9090(4.0.0.1)] SCF-00037: Application quiesce for plugin [domino] failed with error [] and exit code [1], Exiting!
########## Application Unquiesce ##########
[2013-12-05 14:39:18,258] DEBUG: [localhost:9090 (4.0.0.1)] domino::setENV finished successfully
[2013-12-05 14:39:18,258] INFO: [localhost:9090 (4.0.0.1)] UnQuiescing databases
I have seen others with the ltd-000002 error, but none with the subsequent error SCF-00037.
Any ideas why my Quiescing fails?
2 REPLIES 2
spinks
Greetings,
To get more details we will need to see the debug log.
This should list more information, hopefully including the actual error.
You can post here or email it to me at:  spinks at netapp dot com.
Thanks,
John
shultgren
Email sent with several debug logs.
Thanks!
Stefan
