Data Backup and Recovery
Discovery problem with snap creator and kvm
LORENZO_CONTI
Hi,
I'm trying to use snap creator 4.1 to backup our kvm vm images. Image files are in qcow2 format and resides on a nfs volume that is mounted on kvm hosts.
I have installed snapcreator agent on the kvm host and configured a backup profile. When I try to backup the operation hangs for some minutes at this point:
########## Application Discovery ##########
[2014-01-29 09:28:45,180] INFO: Performing discovery on : kvm
And then fails, here's the complete log
[2014-01-29 09:28:43,991] DEBUG: Workflow : backup started with workflow id : 23
[2014-01-29 09:28:43,991] DEBUG: Version: Snap Creator Framework 4.1.0
[2014-01-29 09:28:43,992] DEBUG: Profile: kvm
[2014-01-29 09:28:43,992] DEBUG: Config: backup_vm_img
[2014-01-29 09:28:43,992] DEBUG: Action: backup
[2014-01-29 09:28:43,992] DEBUG: Plugin: kvm
[2014-01-29 09:28:43,992] DEBUG: Policy: daily
[2014-01-29 09:28:43,992] DEBUG: Volume Name: detect
[2014-01-29 09:28:43,993] DEBUG: Snapshot Name: scsnap-daily_20140129092843
[2014-01-29 09:28:44,112] INFO: Validating policy: daily finished successfully
########## Detecting Data ONTAP mode for auto ##########
[2014-01-29 09:28:44,566] INFO: STORAGE-03031: Getting system version details of [cafaro]
[2014-01-29 09:28:44,567] DEBUG: <system-get-version/>
[2014-01-29 09:28:44,567] DEBUG: <system-get-ontapi-version/>
[2014-01-29 09:28:44,568] INFO: STORAGE-03032: Getting system version details of [cafaro] finished successfully.
########## Agent validation ##########
[2014-01-29 09:28:44,894] INFO: Agent validation completed successfully for agent 192.168.86.166:9090
########## Plugin validation ##########
[2014-01-29 09:28:44,925] INFO: Plugin validation completed successfully for plugin kvm
[2014-01-29 09:38:51,134] ERROR: [192.168.86.166:9090 (4.1.0.1)] Operation failed. Reason: Executor timed out. Make sure plugins/wrapper/wrapper binary has execute permission set. Increasing WRAPPER_TIMEOUT_IN_MSEC in agent.properties may help, too.
[2014-01-29 09:38:51,136] ERROR: [192.168.86.166:9090(4.1.0.1)] SCF-00028: Auto Discovery for plug-in [kvm] failed with error [validation failed] and exit code [102], Exiting!
[2014-01-29 09:38:51,143] DEBUG: Workflow : backup_OnFailure started with workflow id : 24
[2014-01-29 09:38:51,143] DEBUG: Version: Snap Creator Framework 4.1.0
[2014-01-29 09:38:51,143] DEBUG: Profile: kvm
[2014-01-29 09:38:51,143] DEBUG: Config: backup_vm_img
[2014-01-29 09:38:51,143] DEBUG: Action: backup_OnFailure
[2014-01-29 09:38:51,143] DEBUG: Plugin: kvm
[2014-01-29 09:38:51,144] DEBUG: Policy: daily
[2014-01-29 09:38:51,144] DEBUG: Volume Name: detect
[2014-01-29 09:38:51,144] DEBUG: Snapshot Name: scsnap-daily_20140129092843
########## Application cleanup ##########
[2014-01-29 09:38:51,789] INFO: Performing cleanup on : kvm
[2014-01-29 09:39:02,159] ERROR: [192.168.86.166:9090 (4.1.0.1)] Operation failed. Make sure plugins/wrapper/wrapper binary has execute permission set. Also try increasing WRAPPER_TIMEOUT_IN_MSEC in scAgent/etc/agent.properties
[2014-01-29 09:39:02,161] ERROR: [192.168.86.166:9090(4.1.0.1)] SCF-00074: Cleanup for plug-in [kvm] failed with error [null] and exit code [102], Exiting!
########## Agent Workflow Finalization ##########
[2014-01-29 09:39:02,170] INFO: Agent Workflow Finalization started
[2014-01-29 09:39:12,985] INFO: [192.168.86.166:9090 (4.1.0.1)] Finalized workflow with id 23
[2014-01-29 09:39:12,985] INFO: Agent Workflow Finalization finished successfully
########## Snap Creator Framework 4.1.0 failed ##########
[2014-01-29 09:39:13,028] INFO: Pre Exit commands are not defined. Skipping !
I have checked against SCF-00028 with no success.
Can you help me fix this issue?
Thanks
Il messaggio è stato modificato da: Lorenzo Conti
The only way to fix is doing this setup  APP_AUTO_DISCOVER=N  in the following config files
/SCSERVERDIR/scServer4.1.0/engine/configs/PROFILE/CONF and
/SCSERVERDIR/scServer4.1.0/engine/etc/validation/plugins/kvm.conf
Is it the right way to do it?
5 REPLIES 5
sivar
Please email me a scdump (available via Action->scdump in the GUI)   My email address sivar at netapp.com
APP_AUTO_DISCOVERY=Y along with KVM_VM_MAPPING=auto:detect:detect will make the kvm plugin to discover vms.
If you don't have any VMs in the hypervisor, the discovery will fail. (or if the KVM_VM_MAPPING has any syntax error)
Do you have these parameters in your config file? (Look for the required variables)
### KVM Settings ###
# KVM_RESTORE_VM_LIST - (required only during restore) List of VMs to be restored.                               #
#                       ie: RHEL5U6,RHEL5U7        #
# KVM_VM_MAPPING - (required) List of mapping b/w VM and its associated storage controller, lun/file path.       #
#                  This param will be updated dynamically during discovery process.                              #
#                  ie: RHEL5U6:fas3170-201-76:/vol/vol_KVM/RHEL5U6;RHLE5U7:fas3170-201-76:/vol/vol_KVM/RHEL5U7;  #
# KVM_VM_CONFIG_DIR - (optional) Path to the directory where all the VM's XML configuration files will be stored.#
#                     Default value: /etc/libvirt/qemu                                                           #
# KVM_CMD_RETRY_COUNT - (optional) The number of times the command will be re-tried when failed in KVM plug-in.  #
#                       Default value: 3        #
KVM_RESTORE_VM_LIST=
KVM_VM_MAPPING=
KVM_VM_CONFIG_DIR=
KVM_CMD_RETRY_COUNT=
These are the validate parameters file content for KVM plugin
SC_AGENT_TIMEOUT=600
APP_DEFINED_RESTORE=Y
APP_CONF_PERSISTENCE=Y
USE_PROXY=N
LORENZO_CONTI
Hi Siva,
Here are our settings:
in
USE_PROXY=N
in
scServer4.1.0/engine/configs/kvm/backup_vm_img.conf
#     Application Options        #
APP_NAME=kvm
APP_IGNORE_ERROR=N
PYTHON_OPTS=
APP_DEFINED_CLONE=N
JAVA_HOME=
PYTHON_HOME=
FS_NAME=
JVM_ARGS=
PERL_OPTS=
PERL_HOME=
PLUGINS_FORWARD=
VALIDATE_VOLUMES=
JAVA_CLASSPATH=
PLUGINS_RESTORE=
APP_DEFINED_BACKUP=N
APP_DEFINED_UMOUNT=N
PLUGINS_REVERSE=
APP_DEFINED_MOUNT=N
#     Archive Options        #
ARCHIVE_LOG_RECURSIVE_SEARCH=N
ARCHIVE_LOG_DIR=
ARCHIVE_LOG_EXT=
ARCHIVE_LOG_RETENTION=
ARCHIVE_LOG_ENABLE=
#     Plug-In Parameter        #
KVM_SUSPENDED_VMS=null
KVM_CMD_RETRY_COUNT=3
KVM_VM_CONFIG_DIR=/etc/libvirt/qemu
The only way to get snapshot done is disablin auto discovery as said in my first post.
Thank you
sivar
Thank you. I will pass this on to the KVM plugin developer and get back to you with an answer.
Clemens_Siebler
Hi Lorenzo,
would you be so kind and email me scAgent/logs/agent.log? I think that would be helpful to further lock down the issue.
If you could do a quick check, do the folders (in the scAgent) plugins/wrapper/in and plugins/wrapper/out exist? The file plugins/wrapper/wrapper should have execute permission. There was one similar know issue, which has been fixed. Unfortunately, I cannot tell you exactly, when the fix will be available.
Thanks,
Clemens
LORENZO_CONTI
Hi Clemens,
here is an ls of ~plugins/wrapper dir
# cd /SC_41/scAgent4.1.0
# ls -l plugins/wrapper/
totale 5696
drwxr-xr-x 2 root root       6 gen 30 11:11 in
drwxr-xr-x 2 root root       6 gen 30 11:11 out
-r-xr-xr-x 1 root root 5831584 gen 16 13:06 wrapper
Regarding the agent.log file, can you give me your email address in order to send it?
Thank you
Lorenzo
