Data Protection
NetApp 2220/2240 and Tape Library Connectivity
GARTHNET599
Hi All,
Our company are looking to introduce a few 2200 series units and would like to use existing Overland NEO100S (IBM) tape backup units for direct connection to the filer. From what I can see the interfaces for SAS on the filer and SAS on the tape unit are different (smaller on the tape unit) can anyone confirm if there is any type of convertor/cable that would allow the connection? If it helps I believe the units we will be using will be running 7-modè software.We were hoping to use Snap Protect to manage the whole process too.
Thanks in advance for any suggestions.
Garth.
1 ACCEPTED SOLUTION
MACKAYDMAJENTA
X6543a-R6 is listed as a 2m QSFP+ to MINISAS cable on HW universe, this is the required cable for miniSAS to QSFP+
There are two options, 2M and 5M
Part No
Begin
End
Length
SAS
X6543A-R6
miniSAS
QSFP
2m
Cable,miniSAS Cntlr-Shelf,2m
X6544A-R6
miniSAS
QSFP
5m
Cable,miniSAS Cntlr-Shelf,5m
3 REPLIES 3
MACKAYDMAJENTA
Part No
Begin
End
Length
SAS
X6543A-R6
miniSAS
QSFP
2m
X6544A-R6
miniSAS
QSFP
5m
malikankor
dont forget to have a look at the compatability matrix to make sure the tape library is supported by the FAS and the ontap version
GARTHNET599
Thanks very much, just what I was looking for. Regards, Garth.
